Pasenger window problem
Can anyone offer any advise please.
My passenger window goes down with no problem but when I put it up it goes about 2/3 the way up then back down to 1/3 up (approx) and stops.
Each time I try to shut it the same happens, the after probably 10 or so times it closes properly.
I have checked the channel to see if anything thing is stopping it but it all seems clear and smooth.
Any advise appreciated.
Thank you
Thank you
maid marianne
Re: Pasenger window problen
maid marianne wrote:Can anyone offer any advise please.
Thank you
allright ,
ive the same problem on a door,problem is the orientation of the channel....which appears to be adjustable.havnt done mine yet.
k1nty
Had that with mine just gave the runner that comes out of the door and the rubber all round the window a good clean, now all works fine.
Re: Pasenger window problem
very very common, ive yet to see a calibra that dont do it, just remember where it stops and goes down, and just stop it your self and tap the button to get it the rest of the way!
Thank you all
I am going to try the stop/start Jamesboy
No time for cleaning today as I want to be out driving
But should have time to give it a clean tomorrow Mark 1.
Will let you know how it all goes
maid marianne
ahhh t5hats what was wrong with my vectra window, as it shut aquint, thats easy to do, i just put up with it on ine, it adds character imo
Thanks a lot
And guess what, used my car today, each time I had to close the window it worked perfectly
Must be something to do with the advise on here
maid marianne
