Fingers X!
will it pass?
Poll ended at Sun May 30, 2010 10:05 pm
Pass! :-)
6
40%
Fail! :-(
9
60%
Total votes : 15
Fingers X!
by big_gordy » Thu May 27, 2010 10:05 pm
well after my car being of the road since last billing time to get her an MOT! hope she passes
as i have had my neibour help me do some reapirs
ie
2x track rod ends
2xwishbones
2xdrop links
new back breaks
4x new tyres
oil changed
water in heating system changed
new back end exhaust
new wipers front & back
what you think? :whistle:
Re: Fingers X!
by maid marianne » Thu May 27, 2010 10:11 pm
You have checked all your light bulbs haven't you :wink:
maid marianne
Re: Fingers X!
by tazz666 » Thu May 27, 2010 10:36 pm
have you checked your
horn
windsreen washers+wipers
brake pipes
fuel pipes
windsreen no crack in eye line
main structual parts for no rot
ie chassis rails suspension mounting points
seatbelts
abs working properly
wheel bearings
Re: Fingers X!
by Fraz » Thu May 27, 2010 10:39 pm
number plates, brake hoses, light alignment
Re: Fingers X!
by big_gordy » Thu May 27, 2010 10:47 pm
had mot sheet to tick of so yes checked
number plates
brake hoses
horn
brake pipes
fuel pipes
light bulbs
seatbelts
wheel bearings
light alignment ill get them to sort if needed when in
Re: Fingers X!
by maid marianne » Thu May 27, 2010 10:57 pm
Its a yes from me then :lol:
Good luck :D
maid marianne
Re: Fingers X!
by big_gordy » Thu May 27, 2010 11:10 pm
so Mr N did u vote fail? :shock:
Re: Fingers X!
by Fraz » Thu May 27, 2010 11:15 pm
big_gordy wrote:so Mr N did u vote fail? :shock:
yes I did ...simply because you or this guy dont have the facilities to check it over correctly, and there is so many areas that is at the discretion of the tester at the time
who was the one for a pass??
Re: Fingers X!
by v6 steve » Thu May 27, 2010 11:17 pm
me!!!!!!!!
Re: Fingers X!
by big_gordy » Thu May 27, 2010 11:39 pm
awww ty steve! no like ya
lol
Re: Fingers X!
by v6 steve » Thu May 27, 2010 11:42 pm
yee but what do i know since i had ma knock to the head :doh:
Re: Fingers X!
by big_gordy » Thu May 27, 2010 11:50 pm
what knock on the heed?
Re: Fingers X!
by vinny_69 » Fri May 28, 2010 12:08 am
i said fail but i hope it passes :D
Re: Fingers X!
by Robs-se » Fri May 28, 2010 12:39 am
Have you emptied the ash tray?
Re: Fingers X!
by big_gordy » Fri May 28, 2010 12:44 am
i dont smoke :-)
