2 Problems on SE9 Help Needed
by vauxhallvictor101 » Sun Apr 18, 2010 11:43 pm
Oil Pressure Gauge, needle goes right across to opposite stop when ignition is turned on, Speedo sometimes works or will stop in 80mph position and stay there, weird all suggestions are welcome as I am not a mechanic and trying to restore an SE9 V6, thanks.
vauxhallvictor101
Re: 2 Problems on SE9 Help Needed
by marko » Mon Apr 19, 2010 6:41 am
pressure guage will be the sender unit or connector to the sender, give the connection a clean.
marko
by Calibra_Mike » Mon Apr 19, 2010 7:10 am
you might not have a sender unit, same problem i have with my gauge, although I have a sender unit now just gotta fit it...
by Mark1 » Mon Apr 19, 2010 7:41 am
You shouldn't know it stops at 80!! :D
by k1nty » Mon Apr 19, 2010 11:36 am
as above ,remove rh front wheel you will the the oil pressure switch.poking behind crank pulley..should be two wires on it.as said connection go crusty .r.e the speedo...sounds like duff clocks,need a replacement set from a v6.there was a set in the for sale on here.
k1nty
by RobbieV » Mon Apr 19, 2010 4:19 pm
Calibra_Mike wrote:you might not have a sender unit, same problem i have with my gauge, although I have a sender unit now just gotta fit it...
All V6's after 96 should have a battery & volt gauge fitted as standard, location of sender unit in pic.
by v6man54deg » Mon Apr 19, 2010 4:32 pm
My oil pressure gauge went the same way last week, I found a break in the wire that connects to the pressure switch body, the plug in the middle is for the oil pressure light that was ok
v6man54deg
by vauxhallvictor101 » Mon Apr 19, 2010 11:04 pm
Thanks for replies will check out weekend, thanks guys, just not sure if I should buy the clocks yet as could the fault be sensor?
vauxhallvictor101
by vauxhallvictor101 » Mon Apr 19, 2010 11:13 pm
TC no lights showing abs also no lights showing, so previous owner could have pulled bulbs, just a guess as I havent pulled the clocks.
vauxhallvictor101
by vauxhallvictor101 » Mon Apr 19, 2010 11:22 pm
will do, post results later thanks.
vauxhallvictor101
