another day another problem (flat battery)
it all started last friday
leave the car for a few hours .......click...click.....click
to be honest im fed up pushing it, yeah i know not a good idea to push start a car with a cat (convertor not a moggie) but ive got a spare anyway
ive checked the battery thats fine, replaced the alternator to be on the safe side still flat, now ive got a spanking new starter motor that i will fit saturday as someone thinks it might be that pulling the extra current, but i have my doubts, something about the solenoid or something.
my question is this
if it's not the starter motor what else should i try?
a friend of mine thinks i should be pullinga fuse every time i park it up for the night but looking in the fuse box thats kind of a long winded approach to the problem, ive had a wee search so ive checked all the interior lights glove box, boot and such
i dont suppose anyone has compiled a list of all the multimetre reading from all the fuse numbers when the ignition is off have they?
my question is this
Re: another day another problem (flat battery)
Quicker to get an auto electrician in to do the job
im starting to think posting something about stuff i have no knowledge about is a bad idea
i will replace the starter motor and if that dosnt solve the problem call an auto sparky as i don't think it will end well if i have a crack at it
oh get on with it you woss
Fraz wrote:oh get on with it you woss
get on with what im at work
Is the battery actually holding its charge? How did you check it?
MarkSE7
dont you just love it then the ele guys explain things
its always clean as mud to me
well ive changed the starter moter so we shall see whats what
right its still playing up chaps
my friend seems to think its more of an ignition problem he says maybe crank Relay????
it's firing up but is cranking over very slow till it fires any ideas?
MarkSE7 wrote:Is the battery actually holding its charge? How did you check it?
MarkSE7
the battery has been tested by 2 garages and its in good working order 78% it just seems to not have enough power to fire the engine up to full speed even after a run it struggles to fire her up.
so i do have some kind of large drain someplace
earth on the engine ?? simple test get a jump lead from earth on battery to good earth point on engine and try it
and try another battery ...its not that hard
and it should turn over at normal speed then?
if it does ?????
if it dont ?????
if it does ?????
if it dont ?????
Crank relay on a metro....that would be the starter solenoid
Users browsing this forum: Bing [Bot] and 41 guests
