Dash lights
Dash lights
by Calibra_Mike » Thu Mar 04, 2010 7:04 pm
Can someone put a pic up of the lights that should come on when you first put the key in on the 2.0 ecotec? I think i might have one missing :(
Re: Dash lights
by James_Mould » Thu Mar 04, 2010 10:01 pm
This is what I get up when I turn my ignition on. Hope it helps. What you think you've got missing then?
Re: Dash lights
by James_Mould » Thu Mar 04, 2010 11:03 pm
The hand brake was off when i took my pic.
Re: Dash lights
by k1nty » Thu Mar 04, 2010 11:07 pm
does every calibra fuel gauge run there normally ...lol
just above red?
k1nty
Re: Dash lights
by James_Mould » Thu Mar 04, 2010 11:10 pm
:lol: I see what you mean. But yes mine has hardly got any fuel in it as it hasn't been out for a while.
Re: Dash lights
by k1nty » Thu Mar 04, 2010 11:10 pm
the turbo gauge is at same point,mine was too till i put a 20 in today.
k1nty
Re: Dash lights
by Calibra_Mike » Fri Mar 05, 2010 12:02 pm
Cheers, ill double check mine and see if i am missing anything :D
Re: Dash lights
by Calibra_Mike » Fri Mar 05, 2010 4:02 pm
yep was missing the EML and the battery light... though for a min the guy i bought it from might have taken out the EML to find a faul but the bulb was there just not working so I replaced it and the battery bulb and all lights come on now... new problem though which i've put in a new thread...
Re: Dash lights
by Calibra_Mike » Mon Mar 08, 2010 7:06 pm
funny though cos i thought the battery light had to be on for the charging system to work? and i swear my battery lights not worked since I bought the car a week or so ago... hmmm
Re: Dash lights
by anasib » Thu Feb 17, 2011 1:16 am
does any one telll me what is the mening of 3rd,4th,and 5th light from the lift in above pic
anasib
Re: Dash lights
by v6 steve » Thu Feb 17, 2011 9:32 am
1. water level in header tank
2. light bulbs working
3. i think is brakes
all these should go out after a couple of secs, apart from the number 2 which goes out once you press the brake pedal
