ABS Light coming on
ABS Light coming on
Over the last few days the ABS light has been coming on now and then, when i turn the car off and restart it goes out but then can come on again when it feels like it.
Is this prob just some dirt etc on one of the toothed rings?
Re: ABS Light coming on
read the fault codes and see what they say
What pins do i short to read ABS codes?
Pins A+K
16 LH Front Solenoid ( Relay & Connections )
17 RH Front Solenoid ( Relay & Connections )
18 Rear Solenoids ( Relay & Connections )
19 Solenoids Relay Circuits
25 Faulty Sensor toothed Ring
35 Pump Relay Circuits
37 Stop Lamp Switch ( Pedal Switch )
39 LH Front Speed Sensor ( Air Gap & Operation )
41 LH Front Speed Sensor ( Resistance & Connections )
42 RH Front Speed Sensor ( Air Gap & Operation )
43 RH Front Speed Sensor ( Resistance & Connections )
44 LH Rear Speed Sensor ( Air Gap & Operation )
45 LH Rear Speed Sensor ( Resistance & Connections )
46 RH Rear Speed Sensor ( Air Gap & Operation )
47 RH Rear Speed Sensor ( Resistance & Connections )
48 System Voltage High/Low ( Alternator & Battery )
55 Faulty ECU
55 Faulty ECU
Users browsing this forum: Bing [Bot] and 32 guests
