heater blowe not working
heater blower not working.worked intermitantly for a few days then packed up.with wet cold weather here need help fast!!!!!!
msb
Re: heater blowe not working
Could be the switch, or the motor has packed up
Theres a fuse on the heater resitor fitted to the end of the motor under the scuttle panel and bets it's gone open circuit??
Search ebay, cost about £15 or if you have a maplin nearby a couple of quid and a bit of time with a soldering iron
Worth checking first before you buy new motors etc Not easy to get too mind you.
Will
Will
WillsToy
