pic request, v6 alternator + fan please
hi guys and gals, as above really. didn't get a chance to look at the se9 today as was to busy tinkering with the mazda
and tidying up the se8 as she's going saturday
anyone got a pic of the rear of the v6 alternator and maybe the fan
just so i can get my head around what it should look like
rob.
rob.
flat-eric
Re: pic request, v6 alternator + fan please
second pic down is the rear of the alternator
the car is parked on gravel at the moment so i cant jack her up but i have a battery on charge for the weekend so i can whack her on the driveway to take a proper peek at the offending item!
here's what i can see so far!
the lump.
the (recon) unit.
as i say, i'll have a go at getting closer at the weekend one the se8's gone and i have more space.
rob.
the lump.
the (recon) unit.
rob.
flat-eric
cheers vinny but im after a shot from the other side, with wiring if possible.
rob.
flat-eric
take the drivers side wheel off and you can get a good look side on
drive shaft off,drop the down pipes gives you loads more room
vinny_69 wrote:take the drivers side wheel off and you can get a good look side on![]()
ha ha, and there lies my next problem! no locking wheel nut key! "doh"
dunno if its a vauxhall jobbie, has three small holes.
flat-eric
yep sound like vx poo
(cant remember the exact size)a 16mm bit and a big hammer would do it
hammer the bit into the locking nut and remove as normal
hamer on a impact socket then break it off, there is only 2 wires going to the alternator so dead easy the cooling fan is under the black plastic tube to the right of the engine in your first pic with the white lable
if the recon unit is a duff one, can i get new brushes for it and hope for the best?
i'm expecting to find a melted alternator when i take a look!
rob.
rob.
flat-eric
if i was you i would take it out and get it recond or buy a new one as its a night mare of a job so i wouldnt be wanting to do a temp job and hope for the best
v6 steve wrote:if i was you i would take it out and get it recond or buy a new one as its a night mare of a job so i wouldnt be wanting to do a temp job and hope for the best
is there any way of testing it to c if its not the alty at fault?
i just wanna cover all the possibilities as they aint cheep!
rob.
flat-eric
have you checked if the ignition light is coming on yet??
Fraz wrote:have you checked if the ignition light is coming on yet??
battery not charged enough, if i put the battery in and turn the key it goes nuts as its not charged enough.
rob.
flat-eric
what you charging it with...one of these mouse wheel chargers??
