Help!! Ball joint issues!
Hi folks. Just in the middle of lowering the cally, only, we've hit a brick wall! How on earth do u get the ball joints apart without mullering them??? Have ball joint splitters, but there just not budging! Even when their apart, the bottom ball joints, can't get the splitter on them! HELP!! Any hints/tips people???
Cheers....
Cheers....
Crazychick
Re: Help!! Ball joint issues!
I assume you have taken the nut off the bottom. Certain ball joint splitters can damage them but it sounds like a case of giving them a good clout, they will come eventually
Yeah, bottom nut is off....been clouting it like mad, and still it won't shift!
How do u get the bottom ball joint off then?? Cant get the splitter on it..
Crazychick
a big bar between the drive shaft and lower arm and a hammer
thats how Unkle Damo taught me
vinny_69 wrote:a big bar between the drive shaft and lower arm and a hammerthats how Unkle Damo taught me
Yep, sussed that....brute force and ignorance! Now, how do u get the damn shock cartridge out! ?????
Crazychick
much the same mate at the top of the cartridge there is a round cover nut type thing,both of mine were stuck solid,so you get your hammer and chisel and try and knock it left
(lefyt loosie rightie tighty) it helps if you have some new cover nuts as the old ones are gonna get fecked.any more questions?
Cheers Vinny. We have finally admitted defeat for today. 8hrs solid on it has taken it's toll....my hands are killing, and I have lost the will to live at the mo
Shall have another go tomorrow....
Crazychick
I would never leaver off the drive shaft ...thats asking for trouble
the top nut will come of the strut if you have a vice or a workmate and a very large pair of stilsons (or a spanner) thats once you have stripped the strut of the springs of course
If you need help I'll send Toby, about time the little sod did some work
your new shocks should come with new nuts i put mine in the in the vice and turnned the shock
v6 steve wrote:your new shocks should come with new nuts i put mine in the in the vice and turnned the shock
Now, there's an idea!! Nice one!
Thanks guy's....
Mark, prime Toby, cause he may well be needed!!
Crazychick
