one bump too far
Re: one bump too far
by Mark1 » Fri Jan 23, 2009 6:08 pm
I don't hit pot holes I drive around them as wheels won't like it.
Club Treasurer
Club Treasurer
by vinny_69 » Fri Jan 23, 2009 6:34 pm
i do most of my driving at night mark so sometimes these things happen
i might also go down the 16's route with a slightly taller profile
by Mark1 » Fri Jan 23, 2009 6:41 pm
You can go for a taller profile on the wheels you have which would save you some money.
If you go 205/45/17 it well be within 0.16% of the standard wheels, also check the pressure.
Club Treasurer
Club Treasurer
by vinny_69 » Fri Jan 23, 2009 6:50 pm
what pressure would you recomend mark i used to have the se8's at 32 bar havent even checked the V6's yet :oops:
so i might just bung on some new shocks and switch the TC off :lol:
by cornishtaz » Fri Jan 23, 2009 6:54 pm
Never had any probs when I had her. Hitting large potholes wont help seeing as your on 215/40/17. If you've got the spare cash go for the full Gmax setup same as Robbie and Neil, I only fitted Gmax springs (so me bad). As for the ABS might have dislodged something when you hit the pothole.
cornishtaz
by Mark1 » Fri Jan 23, 2009 6:58 pm
I run 34 alround on my 18's and it seems to drive ok, if you are going to change the shocks I'd use Koni's or go for a coilover kit that way you can set the car up as you want it. Toby's just got a set of coilovers for his Cosra :shock:
Club Treasurer
Club Treasurer
by vinny_69 » Fri Jan 23, 2009 7:01 pm
the ABS light stayed off on the way to work today but i will give it a wee look on sunday poss d/s sensor
and i will be giving performance tuning a call sometime soon and see if i can get some braided lines too.
or depending on the price Autotint
by tazz666 » Fri Jan 23, 2009 8:19 pm
i have a sensor if you need it vinny
by vinny_69 » Fri Jan 23, 2009 8:21 pm
i know its off my se8 :lol:
by kdchorse2 » Fri Jan 23, 2009 8:45 pm
I need a phone with a camera, last calibra needed two wishbones after went over missing pice of road in Hertfrodshire...with camera I would have claimed.
kdchorse2
by tazz666 » Fri Jan 23, 2009 8:55 pm
vinny_69 wrote:i know its off my se8 :lol:
, no i have two spare ones from the v6, so na na na na na :D
by vinny_69 » Fri Jan 23, 2009 11:11 pm
well i took a trip to mc D's and it still didn't light up so eithert it sorted itself out or the bulbs blown :lol:
but i have the Gmax kit winging its way to me :D
by Robs-se » Sat Jan 24, 2009 12:51 am
I have GMAX on mine, lowered 40mm and yep the roads in Luton are killing me as well, drive around one pothole and hit a bigger one :(
by vinny_69 » Sat Jan 24, 2009 12:53 am
rob have you just got the springs or the full kit?
by henry*r » Sat Jan 24, 2009 9:32 pm
Hi, I've read your posts & I must say I'm using Bilstein shocks with Eibach Springs (35mm) & the set up is really good. When driving on standard 15" or 16" wheels very smooth & same comfort as factory suspension setup. The change came when I fitted 17" BBS's, it's still smooth on a good road but driving over pot holes feels a bit rougher :( so probably just avoid potholes :D
