Fault Codes
Fault Codes
by eco16v » Wed Oct 08, 2008 6:56 pm
Just did the paperclip test on my cally and it has brought up 2 fault codes,
38 - oxygen sensor circuit, voltage high and 92 - camshaft sensor, incorrect signal. Tried clearing the codes but they just re log when the eml comes on. I take it the next step is to replace both the sensors?
eco16v
by vinny_69 » Wed Oct 08, 2008 6:58 pm
sounds like cam sensor is deffo fooked
by eco16v » Wed Oct 08, 2008 7:41 pm
prob been fooked 4 quite a while, only discovered yesterday during my hunt for the trip comp plug that the previous owner had removed the EML bulb!
eco16v
by vinny_69 » Wed Oct 08, 2008 7:44 pm
ouch not a good find
by eco16v » Thu Oct 09, 2008 3:03 pm
anyone got any suggestions other than replacing the sensors?
eco16v
by RAINMAKER » Thu Oct 09, 2008 3:07 pm
only one choice here i think....
RAINMAKER
by eco16v » Thu Oct 09, 2008 3:42 pm
well there is another choice.... take the bulb out again! lol
eco16v
by vinny_69 » Thu Oct 09, 2008 4:20 pm
RAINMAKER wrote:only one choice here i think....
agreed replace both and that should be the end of your probs mate 8)
then put the eml bulb back in :lol:
by eco16v » Thu Oct 09, 2008 6:38 pm
a trip to the scrappys it is then!
eco16v
by Phantom » Thu Oct 09, 2008 6:54 pm
did you do the paper clip test with the engine running or not? as unless the cam sensor has gone it will throw that fault code if the engine isn't running, certainly sounds like you need a new lambda sensor though
Phantom
by cornishtaz » Thu Oct 09, 2008 6:55 pm
I wouldn't use a 2nd hand crank sensor, as there is no way of telling if its knackered until you fit it.
cornishtaz
by eco16v » Thu Oct 09, 2008 7:07 pm
did it with engine off, tried it when engine was running but doesnt show anything up, but after running for a few secs EML comes on and doesnt go out til u switch engine off and then on again.
eco16v
by Phantom » Thu Oct 09, 2008 7:15 pm
with the link in place the eml light should flash the codes when the engine is running even if there isn't any fault codes it will flash the self check codes
Phantom
by eco16v » Fri Oct 10, 2008 11:23 am
mine isnt flashing at all when the engine is running. Drove car this morning and EML didnt come on, but when started last nite EML came on after automatic choke cut out, i revved the car a few times and EML went out again!
eco16v
by eco16v » Wed Oct 15, 2008 7:39 pm
Replaced oxygen sensor with 1 off a vectra 1.8 and fault codes are now cleared!
eco16v
