Cally wheel offset
Cally wheel offset
by cornishtaz » Sun Mar 30, 2008 1:09 pm
Well I'm on the lookout for some nice 17's for my Cally, the problem I'm having is trying to find a set that has an offset of ET49( the recommended offset). My question is what is the max difference I can go without the wheels sticking out too far, I've seen on one wheel website that the Cally can take ET35-ET45 offset.
My car isn't lowered yet but will be in the future by 30-40mm and I know I've got to have 5x110 PCD.
Views on the offset please.
Thanks in advance
cornishtaz
by fraggie » Sun Mar 30, 2008 1:14 pm
in my opinion matey i wouldn't go any lower than 39 if you want to lower it. I have a feeling mine are 35 and they stick out a little but then im getting the wide arch kit so im not too fussed :)
fraggie
by cornishtaz » Sun Mar 30, 2008 1:15 pm
This is the website I looked at
Wheel offset
cornishtaz
by fraggie » Sun Mar 30, 2008 1:21 pm
fraggie
by Mark1 » Sun Mar 30, 2008 3:16 pm
Best is between 40 and 49
Club Treasurer
Club Treasurer
by cornishtaz » Sun Mar 30, 2008 7:29 pm
Cheers for the info this will make finding some nice wheels a bit easier.
cornishtaz
by cornishtaz » Sun Mar 30, 2008 8:56 pm
Reason for asking is I'm watching a set of Wolfrace Asia Tech Suzuka's on Ebay that have been fitted to a Astra H
Wolfrace wheels
cornishtaz
Wheel offset
by well-dweller » Sun May 25, 2008 7:10 pm
Cornishtaz - I wouldn't trust that website you quoted. Seems like they only want to sell you tyres based on how they look on the car, rather than how your car is going to handle. Try this for offset: -
http://www.carlsalter.com/wheel_fitments.html
Personally I wouldn't want to move away from the manufacturers stated offset. Reason? I had a lightweight import Scooby with about 315 BHP which had a lovely set of gold Kahn 17's on it when I bought it. Must admit, it made the car look the nuts. But they used to scrape on the inner plastic arch with 4 up and going round corners. So I decided to get a set of 18's which were the correct offset. The difference was astonishing/unbelieveable/staggering (It's difficult to describe in words). With the old wheels on it was like riding a mad nutter stallion when driving at speed - you were never sure of which direction the car was going to head off next - ditch, field, another car. With the replacement wheels it was like taming the stallion. Total confidence. The car stuck to the road like sh1t to a blanket. The person who designed your
To calculate the tyres you could try either of these two sites (they should both give the same results). You need to know your standard tyre as your car left the factory. For example, my Cally Turbo came with 205/50x16 as standard. The best 17" to put on it is the 205/45x17. Otherwise you can get speedo or gearing issues. I've seen 205/40x17 tyres on a Cally. IMHO they look daft. Big car, tiny wheels.
Most alloys use plastic spigot rings to bridge the gap between hub and wheel bore. Don't run without spigot rings. I know from experience of taking the wheels back to be re-balanced several times but still had the wheel vibration. I wasn't using spigot rings initially. Well I didn't know, did I!!
well-dweller
Wheel offset
by well-dweller » Sun May 25, 2008 7:13 pm
Sorry, left out the two tyre calculator sites...
http://www.tyresave.co.uk/tyresize.html
http://www.powerdog.com/tiresize.cgi
With the second site you just type
205/50x16
215/40x16
214/45x16
and so on.
well-dweller
by Callyman » Sun May 25, 2008 9:03 pm
Mine are ET40, standard height they are fine with 215/40/17's
Club Memberships
Club Memberships
by cornishtaz » Sun May 25, 2008 10:16 pm
Got a set of wheels et42 will be lowered by 40 when I change the front tyres to correct profile
cornishtaz
