What temp does the fan cut on a C20XE (Redtop)
by KERR_SE9 » Wed May 21, 2008 11:16 pm
As per title,what temp does fan cut in on a redtop, and is there 2 temps ie slow then a full speed?Mine isnt coming on until over 100 deg
by splinter » Wed May 21, 2008 11:25 pm
i have a 2.0 16 valve rad on mine and does not come in till 100 too. if that helps..
by tazz666 » Wed May 21, 2008 11:39 pm
mine comes on at 95 degrees and mine is a little ole red top
by KERR_SE9 » Wed May 21, 2008 11:43 pm
Im a correct in saying the thermostat will dictate what temp the fan comes on or is it the fan switch? Im buying a new thermostat on friday.
by tazz666 » Wed May 21, 2008 11:49 pm
its the fan switch in the radiator mate that switches the fan on, im pretty sure it is
by RAINMAKER » Thu May 22, 2008 1:05 am
the fan should cut in at 95, however you can change the thermostat to one that opens at 82 and also the fan switch to 82 if you prefer this allows the flow to start quicker and the fan cuts in early which helps in traffic i did this to a astar mk3 redtop conversion ran perfect.
RAINMAKER
Users browsing this forum: No registered users and 80 guests
