brake light ...
brake light ...
by BazV6er » Tue May 13, 2008 1:52 pm
just noticed lunch time the light on the dash top right hand corner of the instruments wouldnt go out when i depress the brake so i checked the brake lights and the rear offside doesnt appear to be working and the bulb looks ok not broke inside.
i will try them around later but how do you get the bulbs out of the aperture as it seems a bit stiff to pull out and is there anything else i can try to get it working again.
by Phantom » Tue May 13, 2008 2:34 pm
just push twist & pull out of the holder
Phantom
by BazV6er » Tue May 13, 2008 2:38 pm
ok mate cheers
by BazV6er » Fri May 16, 2008 6:01 pm
yep turned out to be a bulb needing replaced but the filament wasnt broken on the old one.
by Phantom » Fri May 16, 2008 9:37 pm
sometimes the filament will weld itself back together if its knocked whilst driving
Phantom
