Remote locking
Remote locking
by markybrisca » Wed Mar 19, 2008 10:53 pm
Just bought a Clifford remote locking kit as I am too lazy to put a key in a lock and turn it (2xvectra delocked doorhandles on way too) looks like wiring is in passenger footwell, I need live, earth, lock/unlock and connection to hazard switch, can all be found in footwell or do I need to strip down dash as well for more connections? any help appreciated, Mark.
markybrisca
by RobbieV » Wed Mar 19, 2008 10:56 pm
Live and earth can be found back of fuse box, Hazzard wiring is in the passenger footwell and lock/unlock at the central locking module in the drivers footwell.
by markybrisca » Wed Mar 19, 2008 10:59 pm
Cheers mate, also remote module has 1 wire for factory alarm arm/disarm, can my Cally be connected as easy as 1 wire, if so any ideas where it is?
markybrisca
by RobbieV » Wed Mar 19, 2008 11:02 pm
markybrisca wrote:Cheers mate, also remote module has 1 wire for factory alarm arm/disarm, can my Cally be connected as easy as 1 wire, if so any ideas where it is?
Sorry not sure on that.
by markybrisca » Thu Mar 20, 2008 12:26 pm
Can anyone help me identify the wiring colours in the footwell so I dont have to spend ages testing/searching. I need live, earth, lock,unlock, alarm, closure and hazard flash, pleeeaaseeee!!!!!!! Thanks Mark.
markybrisca
by Fraz » Thu Mar 20, 2008 4:02 pm
by markybrisca » Thu Mar 20, 2008 6:11 pm
Cheers mate!
markybrisca
by markybrisca » Fri Mar 21, 2008 11:39 am
Remote locking works fine now, just got to connect window lift wire and indicator flash when I have more time, sweeeeeetttt!!
markybrisca
by markybrisca » Sat Mar 22, 2008 9:57 pm
L
markybrisca
Last bit of help required, I have a wire which will connect to the original alarm. I know the Callys alarm wire is Green and Black but I cannot locate the wire in the passenger footwell, it is supposed to be behind the glovebox but how do you remove the glovebox if I need to? Thanks guys.
markybrisca
by RobbieV » Sun Mar 23, 2008 4:48 pm
Open the glove box, there are 4 screws one in each corner, remove screws and pull the glove-box forward till you can see/feel the connection to the glove-box light and disconnect, now you can remove the glove-box.
