Hand brake - again
Hand brake - again
The usual - parking on a hill facing upwards car rolls back, need to put in gear.
Today i did a bit of fine adjustment, brake on 6 notch, wheels still turn so adjusted using the internal wheel.
Now the car wont move forward even when 1st gear engaged and brake on but will move backwards when reverse is selected.
What am i missing or doing wrong? any ideas?
Rob
Rob
truxx
problem i found was that with the road wheel off and adjusting the brake, when trying the wheel it locked both ways because of the little area that would move ie the drum. On fitting the wheel and then trying the road wheel would move in both directions, this is when i gave the interior wheel a tweek to see if this helped at all. now it locks in a forward motion and not in reverse.
Rob
Rob
ok sounds like you've done it slightly incorrectly.. or i'm mis-understanding, i believe you should set the rear handbrake "wheel" (the bit thats impossible to see and even harder to turn when you do find it) when you have the handbrake only only the third click or so.. tweek each side up untill the drums become locked, you should then find with the handbrake off they spin ok, and with the handbrake up on click 4 or 5 it holds really well.
C411BRAnut
C411BRAnut wrote:I always leave a car parked in gear, whatever I'm driving. Just in case the handbrake fails!
Me too allways have.
As i did a while back after borrowing my mothers car.
She later drove it through the drive gates
Same with my other half,she never checks it's in neutral before starting it
truxx
