angel eye transformer question...
by BazV6er » Fri Nov 16, 2007 11:03 pm
i recenly aquired 2 sets of angel eye neon rings to convert into my lights , but they never came with any transformer blocks only bare wires.
Ive looked on fatladz old website
http://www.aqth92.dsl.pipex.com/calibra ... _guide.htm
and it doesnt say how you connect them to normal lighting systems...can anyone help and give me a bit of advice how to link them
by RobbieV » Fri Nov 16, 2007 11:19 pm
Are we talking about the one's i gave you ?
by BazV6er » Fri Nov 16, 2007 11:36 pm
yeah rob the ones you kindly gave me
by RobbieV » Fri Nov 16, 2007 11:38 pm
Well they are LED angel rings and don't need transformers like the neon one's do.
Just connect to the side lights, One live and one earth :)
by BazV6er » Fri Nov 16, 2007 11:42 pm
ah i see i thouht they were neon , okay well i guess led is better ,so hows the best way to wire to the sidelights (as ive never done any electrics modifiying before lol...
btw do i still keep my existing sidelights as i found a old thread where someone said the halos replace the sidelights...
by RobbieV » Fri Nov 16, 2007 11:46 pm
Connect one wire to the live and one wire to the earth, if they don't work just swap the wires around.
I connected mine to the side lights and took the sidelight bulb out, you can leave the bulb in if you want to.
by scouse1 » Sat Nov 17, 2007 11:33 am
were can you get the led ones from?
Movie-Torrentz the Home of Quality Movie, Bluray and TVtorrentz
by RobbieV » Sat Nov 17, 2007 3:49 pm
scouse1 wrote:were can you get the led ones from?
They were ripped out of the "sonar" angel eye headlights that are sold on ebay.
The neon angel eyes are better -
http://stores.ebay.co.uk/1llusion-CarSt ... esstQQtZkm
by scouse1 » Sat Nov 17, 2007 5:47 pm
ta for link rob
Listening to: The Cult - Born Into This
via FoxyTunes
by BazV6er » Sat Nov 17, 2007 11:22 pm
ok ive just found a guide for fitting the rings on a ford mondeo here :http://www.fordmondeo.org/wiki/index.php/Angel_Eyes_-_Mk2
, so im sure this will help especially as i can use a connection block for the led angel rings to connect up and because i already have a set of calibra lights i can use these to experiment with.
by BazV6er » Sun Nov 18, 2007 1:39 pm
okay ive just fished my lights out and im not sure about a few things ...
there are 2 separate switches with stalks on the end of them that chappers also gave me ,where do these go and do i have to alter anything
heres some pics:
by Allys Cally » Sun Nov 18, 2007 1:48 pm
arent they the headlight adjusters. the stalk end fits into the hole underneath the plug in baz
by BazV6er » Sun Nov 18, 2007 1:53 pm
okay so they are for the electrical switch inside the car used for raising and lowering the positions is that correct.
ive just had a look under the bonnet but mine look different as it looks like they have a grey plastic screw on the end of the adjuster, is this normal for all models of calibra or are they all different.
by Allys Cally » Sun Nov 18, 2007 2:08 pm
are you saying that yours are manually adjusted rather than electric. got a pic mate?
by BazV6er » Sun Nov 18, 2007 2:19 pm
nah , they just look different from the back....
i know my electrics work inside the car okay so i would say they are still electric.
as for the brightness i know your right dave clear lenses would look better but its a little bit of extra light source and fatlaz started off with the standard cally lights as at the bottom of this link:
