Differrence in brakes power
by ODreams » Fri Sep 07, 2007 5:03 pm
Hi all
MOT people tell me there is a difference of 29% effectiveness between my front left and front right brake.
what i want to know is - will renewing in pads on both, correct this? and if not how do i correct it?
loads of thanks
Eden
ODreams
by boys_toys » Fri Sep 07, 2007 5:16 pm
if your pads & discs are in good condition try bleeding the brakes , could have air in the system , could have a sticky caliper .
does it pull one way under braking ????
boys_toys
by Stupink » Fri Sep 07, 2007 6:17 pm
its almost certainly because of a sticking caliper, often just stripping it down and a good clean out will be ok "for now".. or a recon caliper/pair of calipers is the answer if you're not scared to spend any money.
by ODreams » Mon Sep 10, 2007 4:40 pm
Cheers Guys, it's defo not sticking... i'll give it a good clean.
Eden
ODreams
Users browsing this forum: Bing [Bot] and 18 guests
