For Those With Non Standard Alloys
by Smurf » Fri Jun 25, 2004 8:28 am
I'm hoping this is perfectly normal and it's just that I'm not used to it, but since having 17's on my V6 with 215/40/17 tyres I find that the car is constantly following the ruts in the road and it can pull the car around a bit. I've also noticed on the motorway in lane 3 the car will follow the contour of the road and pull to the right a bit.
I've had the tracking checked twice (both times it was out and was adjusted). If I find a straight piece of road and position the wheel centrally, it'll go in a straight line, but seems to get pulled off by the slightest change on the road.
Do all of you guys with non-standard alloys find the same thing? I'm presuming it must be the lack of tyre compared to my old 15's with 205/55 tyres.
Thanks
Smurf
by jaybv6 » Fri Jun 25, 2004 10:38 am
Neil, It's call tramlining. Basically it's not a trait due to the size of the wheel but the width. It would have been noticeable on 205 section tyres and then the wider the section the more the car tends to follow the grooves in the road. When you up size the wheel there is less bounce in the sidewall aswell so low profiled wiode tyres are more susceptible.
jaybv6
by Mark1 » Sat Jun 26, 2004 7:23 am
I've got the same and as Jay said it's just the width.
Club Treasurer
Club Treasurer
by Robert_Dale » Sat Jun 26, 2004 8:28 am
Same here mate
Robert_Dale
by RobbieV » Sat Jun 26, 2004 4:31 pm
Neil, same problem mate, can be very annoying at times :x
by splinter » Sat Jun 26, 2004 6:31 pm
Same here Neil. and ive 18, and it worse then 17" [img]/smile.gif[/img]
by Smurf » Sat Jun 26, 2004 11:33 pm
Thanks for all the replies guys - it's nice to hear I'm not alone on this [img]/smile.gif[/img]
Smurf
by Furey » Sun Jun 27, 2004 12:41 am
im running 8.5" wide and its difficult to drive it in the slow lane of the motorway. drove a monster truck with 18" wide tyres once and it tried to claw its way all over the place!
by PUMBA » Wed Jun 30, 2004 3:32 am
Hi Guys,
Interest that this topic has been brought up. Because I have found the same with my tyre wheel combination. And i was worried it may have something to do with the alignment.
I bought a second hand set of 16 x 6 calli turbo rims, and fitted them with Goodyear F1 205/16/50's.
The tyre guy said something about the tyres being directional, (in one ear and out the other), and I have noticed that the call tends to won't to follow the curvature of the road.
Thanks guys for the reassurance that this is normal, I've saved myself $60.00.
PUMBA
In-Dash touch screen
by c1emm » Thu Jul 08, 2004 9:23 pm
Same here Neil
i got 215/40/17 tyres
c1emm
by nokia » Thu Jul 08, 2004 9:37 pm
Same here mate!!.............Horses for courses :roll:
nokia
by ®ob » Thu Jul 08, 2004 10:06 pm
Probably a rather dumb question, but does it improve...or worsen if the car is lowered? I am dropping by 40mm soon and was just curious.....
®ob
by RobbieV » Fri Jul 09, 2004 6:38 am
<!--QuoteBegin-®ob+--><div class='quotetop'>(®ob)</div><div class='quotemain'><!--QuoteEBegin-->Probably a rather dumb question, but does it improve...or worsen if the car is lowered? I am dropping by 40mm soon and was just curious.....<!--QuoteEnd--></div><!--QuoteEEnd-->
Will let you know soon [img]/smile.gif[/img] as ive just got some brand new BKracing 322's with 215/40/17 tyres and my car is lowered 40mm.
just waiting for some good weather so that i can paint my calipers.
by Maverick » Fri Jul 09, 2004 6:49 am
Don't think you'll notice too much difference with lowered suspension Rob, but when you lower your car, particularly if you uprate the shocks, you're gonna feel a lot more of what's going on underneath the car. That may also make it APPEAR more extreme.
Maverick
by Dan Willis » Fri Jul 09, 2004 9:25 am
It will be worse with lowered suspension. Simply because there is less travel and things (should be) stiffer.
Try 19s mate... tramlining? Pah! The Porsche has a mind of it's own... [img]/smile.gif[/img]
Dan
