Weird noise/experience
No, this isn't about the time I was laying in bed and I got abducted by aliens....
Last week, I had both my cv boots replaced and my passenger side front wheel bearing. I drove my car off from home and as I stopped this rather odd noise and feeling happened; I put on the brakes and they bit, then it felt like something slipped and gragagaga noise came and my brake pedal vibrated.
The noise/feeling doesn't happen all the time, only when braking. It feels like something is slipping and it seems to loose some brake force. Now, considering it's happened in a day and it is only intermittent, I have no idea. Brake pads don't just give up intermittently do they? (And yes I shat myself when it first happened)
My Mechanic thinks it could be a driveshaft but, he did the work in the first place and why the hell is it happening now?:sob:
Any idea's people?
Any idea's people?
Twigz
Is this when you pull off? The ABS does a test which is why it grinds. I usually maneouver with the brake on when pulling off from my house because it's a tight sqeaze getting out and I get the usual grind from the ABS and off I go.....
Sean
SE5 Turbo
LE 07
LE 16
Turbo
Another Turbo
Se7
V6
16V
8v
SE5 Turbo
LE 07
LE 16
Turbo
Another Turbo
Se7
V6
16V
8v
- Gold Club Member
<!--QuoteBegin-se5+--><div class='quotetop'>(se5)</div><div class='quotemain'><!--QuoteEBegin-->Is this when you pull off? The ABS does a test which is why it grinds. I usually maneouver with the brake on when pulling off from my house because it's a tight sqeaze getting out and I get the usual grind from the ABS and off I go.....<!--QuoteEnd--></div><!--QuoteEEnd-->
i get that too i spent ages cleaning sensors until i didnt bother at al and now you're telling me that lol
DeepSnoozer
Well can honestly say I've never experienced that?
