Fuel Pump Relay - Help Required (from the start)
by hormonedmonkey » Mon May 14, 2007 9:29 pm
After getting the fuel pump changed and that not helping my problem, I am left to the outcome that it is the FUEL PUMP RELAY....
Please help!
WHERE CAN I GET 1? looked on Ebay not sure what 1 i need, could someone point me in right direction?
HOW EASY TO FIT? Could anyone give me some direction?
Thanks peeps!
hormonedmonkey
by RobbieV » Mon May 14, 2007 10:09 pm
Here's a pic, as you can see it's a plug and play thingy [img]/smile.gif[/img]
by hormonedmonkey » Mon May 14, 2007 10:20 pm
where is it located?
hormonedmonkey
by RobbieV » Mon May 14, 2007 10:45 pm
Behind the kick panel driver's side footwell.
by hormonedmonkey » Tue May 15, 2007 8:52 pm
easily done?
hormonedmonkey
by hormonedmonkey » Tue May 15, 2007 8:54 pm
anyone know the part number it is for my 1992 8v?
hormonedmonkey
by Stupink » Tue May 15, 2007 9:06 pm
I think they're all the same part number. so take it off the box in pic above [img]/smile.gif[/img]
by hormonedmonkey » Tue May 15, 2007 9:19 pm
90378 ???? 51
hormonedmonkey
by RobbieV » Tue May 15, 2007 9:24 pm
90378651 fit's all calibra's [img]/smile.gif[/img]
by hormonedmonkey » Tue May 15, 2007 9:31 pm
Thanks everyone!
Hopefully will have my calibra back soon then!
I've only driven her 80 miles in the month i've had it!
hormonedmonkey
by hormonedmonkey » Wed May 16, 2007 5:32 pm
went past a relay at work and they had one on the shelf waiting!
DO I NEED TO DO ANYTHING SPECIAL TO REPLACE?
Or can I just loctae and swap over?
Ta
hormonedmonkey
by RobbieV » Wed May 16, 2007 6:33 pm
Pull out old push in new.
by hormonedmonkey » Thu May 17, 2007 6:08 pm
done. drove car around for about half hour then it died on me again.
i'm stumped.
hormonedmonkey
by Sean C » Thu May 17, 2007 8:52 pm
If you touch the relay and turn the ignition on and off can you feel it clicking? can you hear the fuel pump?
by hormonedmonkey » Thu May 17, 2007 9:05 pm
yes everything seems to be working fine. So I got a bit of an electrics whizz on the case. He by-passed the relay wires or something or other and car was working fine. So seems to be a problem between the relay and ECU or ECU itself....
hormonedmonkey
