engine managment light
right i have tried almost every thing,
the light flickers on around 2500 and 3000 REVS and she tries to die, but only when im in gear and driving it does'nt come on if you just rev the car, i put it on the computer and it said mass air flow meter low voltage, so i changed the air flow meter and it was ok for 30 seconds,
any one got any idear of what the problem is
ps the computer is now showing no codes
andy1
been out in the car tonight and its still doing BUT when i got out of the car i heard a spluter from the back box, so i poped the bonnet and checked the leads and number 4 was not on all the way tried to push it on and it would not clip on to the plug but when i pulled the lead of the plug the bit that is attached inside the lead was still on the plug, i am just woundering if this would be the cause of my e/m/light flshing on
andy1
would the HT lead cause the e,m,light to flash as number 4 is not cliping on all the way what i ment to say was when i put the metal sheild on the lead it seams to miss fire but did notice that the thingy inside the lead has broken but it i leave the shield off, it runs ok but would this cause the light to flicker at speed
andy1
<!--QuoteBegin-ROG+--><div class='quotetop'>(ROG)</div><div class='quotemain'><!--QuoteEBegin-->light occasionaly flicking on at about 3000 revs when driving, ive had it twice, both times was the lambda sensor, no codes stored either time<!--QuoteEnd--></div><!--QuoteEEnd-->where and what is it
andy1
Users browsing this forum: Google [Bot] and 35 guests
