help needed with a bit of work on my car
what do i need to get if my lower balljoint has gone ?would it be better for me to buy two wishbones structures as well as two new anti roll bar droplinks...
<!--QuoteBegin-Baz16v+--><div class='quotetop'>(Baz16v)</div><div class='quotemain'><!--QuoteEBegin-->what do i need to get if my lower balljoint has gone ?would it be better for me to buy two wishbones structures as well as two new anti roll bar droplinks...<!--QuoteEnd--></div><!--QuoteEEnd-->
I would buy 2 wishbones and new drop links, once fitted makes a big difference [img]/smile.gif[/img]
they are riveted in. but they can be removed by drilling out the rivets and fitting the the new balljoints with bolts. it would be a lot easier to fit new lower arms and droplinks.
the rear bushes on both sides on mine have gone. but i cant decide wether to upgrade to powerfelx bushes or buy new lowerarms??
callyben
<!--QuoteBegin-Baz16v+--><div class='quotetop'>(Baz16v)</div><div class='quotemain'><!--QuoteEBegin-->well im gonna have a go at these with the fiancees dad ,are they easy to replace?
im not great at doing mechanical things ,i was gonna take it to a garage but i think they would charge me the earth<!--QuoteEnd--></div><!--QuoteEEnd-->yes matey there easy to fit should take about 35 to 45 min each side and you need a torquewrench matey to do them back up and there 3 setting for them
mickeyboy
You won't struggle if you take your time. Nothing is fiddly at all.
Basically
jack the car up on axle stands.
wheel off
undo the bottom ball joint (easy)
undo the anti roll bar link (easy)
use a balljoint splitter to split the balljoint (easy if you can use a hammer lol)
then just undo the x2 big bolts holding the wishbone into the body/subframe (easy)
pull the wishbone out! (simple!)
Basically
wheel off
Rusty_CallyT
