Trip computer - Switch problem
IIRC the switch is close to £50 from Vx. Im sure someone will correct me if im wrong tho!
I bought the comp and switch together for £35. Why would someone sell them separately? Make more money I guess!!
Then again, If i sold mine, i wouldnt be able to sell the switch or id be left with a hacked up hole in the console from the stanley knife butchery!!
craigmcd82
i just got a computer and switch from a carlton for £12 from the scrappies. The calton switch does not have correct plug so a bit of DIY wiring is needed the colours are the same just strip bback the wires and solder together mine works pervect all i need now is the chip callibrated to my car is there someone on the site who does it?
calibradeek
Hi, have a nose at this site
<a href="http://www.abs-zero.com/FCprogramming.htm" target="_blank">www.abs-zero.com/FCprogramming.htm</a>
and send Ian an email, he done mine for me very cheap and a quick turnaround [img]/smile.gif[/img]
Cheers Rob
Cheers Rob
DC Update on the Rear Panels?
how do you set the clock on the trip computer? i know the 2 tiny holes on the switch are for the hours and minutes and i can set the time ok, but then the clock doesn't advance it just stays on whatever time i set it to. after setting time do you then have to press both tiny buttons together?
Tattooman
Kieran_Burns
MegaVaux - Great Service
The select button is the concave one, I think its larger. Its the one you use to scroll through the functions of the FC [img]/smile.gif[/img]
craigmcd82
Hello
Thanks for answering my question
This is what I have found. The wiring loom from the white block to the computer does not exist.
I went down the breakers and found a cav 2.0 16v.
I took the hand-break console out and found the loom. The loom I found (approx 5 wires) does not exist on my cally.
so I cut the plug off. All I need to do now is find out where the 5 wires go to and how to sire them up.
I will submit photo's over the weekend.
Thanks
James
Thanks
James
calibra
