Oh My God I Just Give Up!!
by simonV6 » Wed Jun 14, 2006 2:01 pm
Anything unusual found yet?? [img]/smile.gif[/img]
simonV6
by Kickingriffin » Wed Jun 14, 2006 2:11 pm
Im stuck in work, gotta look in a bit, when the cv joint was done he did do it real tight with a torque wrench and did put a pin in, but i will check to see if all is well.
Kickingriffin
by Cozy » Wed Jun 14, 2006 3:01 pm
i'd take it back to the person who did the cv joint, seems odd that it has started happening since it got fixed, bring it back, explain whats happening and ask them to look at it again
Cozy
by nigescalli » Wed Jun 14, 2006 3:35 pm
if they have had it to bits check the nut on the balljoint mate had it with his not being tightened properly
nigescalli
by simonV6 » Wed Jun 14, 2006 4:21 pm
Good luck and hope all goes well and its a nice easy fix, and try not to drive too hard or not drive at all if you can avoid it.
simonV6
by Tim2001 » Wed Jun 14, 2006 5:57 pm
Not being funny but were you braking when this juddering occured. The first time people have the abs cutting in a calibra usually scares the crap out of them and makes them think something is wrong.
Tim2001
by Kickingriffin » Wed Jun 14, 2006 8:58 pm
Guess what, thankyou to theperson that said to check my wheelnuts else id be dead! After having the CV joint saturday and going up the 1/4 on sunday at shakespeare i checked my nuts and every single one was loose to the touch on the left hand front wheel, and have to drive to bracknell 2moz!
Kickingriffin
by projectcalibra » Wed Jun 14, 2006 9:04 pm
damn, thats not good, would complain about that
projectcalibra
by Kickingriffin » Wed Jun 14, 2006 9:11 pm
I was well shocked, the hub nut seemed tight though, and the split pin still intact
Kickingriffin
by wilkybar-kid » Wed Jun 14, 2006 9:13 pm
While you are in Bracknell if you see a mag blue calibra floating about be sure to give me a wave wont you. Also you rearly do need to have a word with whoever left the weel nuts lose that is so dangrous I cant explane.
wilkybar-kid
by Kickingriffin » Wed Jun 14, 2006 9:17 pm
I will, going to visit the Waitrose head quarters, yep i nearly didnt check them either, something just told me to.
Kickingriffin
by wilkybar-kid » Wed Jun 14, 2006 9:22 pm
Waitrose is 5 mins down the road from me so you might see me.
wilkybar-kid
by daddycool » Wed Jun 14, 2006 9:23 pm
Thank God you found the cause [img]/smile.gif[/img]
daddycool
by simonV6 » Thu Jun 15, 2006 9:17 am
Glad I was of assistance. good job u spotted it before it was too late.
happened to many of times its scary all of a sudden everything starts shaking.
We will still see you at swindon now then? [img]/smile.gif[/img]
<!--QuoteBegin-Kickingriffin+--><div class='quotetop'>(Kickingriffin)</div><div class='quotemain'><!--QuoteEBegin-->Guess what, thankyou to theperson that said to check my wheelnuts else id be dead! After having the CV joint saturday and going up the 1/4 on sunday at shakespeare i checked my nuts and every single one was loose to the touch on the left hand front wheel, and have to drive to bracknell 2moz!<!--QuoteEnd--></div><!--QuoteEEnd-->
simonV6
by T.F.S. » Thu Jun 15, 2006 1:02 pm
ohhh you have been sooo lucky!!!
normally they just make a banging noise for about 5-7 seconds and then you see it overtake you
this is a perfect example of how important forums can be!
be glad you took notice, i know you are anyway lol
T.F.S.
Users browsing this forum: No registered users and 64 guests
