Suspension travel question
A couple of years ago I lowered my 8v by 40mm on Gmax. However, I had 18's wearing a 45 profile so with people in the car (or without for that matter) the tyres fowled on the arches when driving in general.
So, what I can't decide is this:
Do I go for a 30mm drop? Or will this still rub with people in the car?
Or I could get 30mm drop turbo springs - these are stiffer, and so would withstand more weight?
What do you folks think?
Cheers,
Phil
Cheers,
Phil
Phil
Add some coil spring assisters first and see how you get on...bout £20 quid tops a pair on ebay depending on the coil space. You'll need to measure the space between the centre of the coil and then get a pair relating to that size...approx 30 mil on rears. It should stop the full travel on the spring and hopefully avoid the rubbing. Then re-assess if still fouling the arches.
check this guys egay store:
<a href="http://cgi.ebay.co.uk/SUSPENSION-COIL-SPRING-ASSISTORS-AS3-TOWBAR-TOW-BAR_W0QQitemZ8056125504QQcategoryZ33653QQrdZ1QQcmdZViewItem" target="_blank">http://cgi.ebay.co.uk/SUSPENSION-COIL-SPRI...1QQcmdZViewItem</a>
TonyDTM
Guys, thanks for your responses, BUT (there's always got to be one)
the problems are: 1, I sold the 40mm lowering springs, and bought new standard springs. (it was a desparate measure as it was xmas) So I have no lowering springs to start with.
2, The tyres cost me £130 a corner and are brand new. Springs are cheaper than tyres, hence my decision to change springs in the first place when the problem occurred.
Phil
