What have i done wrong!
<!--QuoteBegin-houston+--><div class='quotetop'>(houston)</div><div class='quotemain'><!--QuoteEBegin-->car passed, was talking to the tester and even he said abs causes accidents.<!--QuoteEnd--></div><!--QuoteEEnd-->
Next time you see your mot tester tell him to read this -
<a href="http://auto.howstuffworks.com/anti-lock-brake1.htm" target="_blank">http://auto.howstuffworks.com/anti-lock-brake1.htm</a>
<a href="http://auto.howstuffworks.com/framed.htm?parent=anti-lock-brake.htm&url=http://www.se-r.net/brakes/abs.html" target="_blank">http://auto.howstuffworks.com/framed.htm?p...brakes/abs.html</a>
<!--QuoteBegin-dicky+--><div class='quotetop'>(dicky)</div><div class='quotemain'><!--QuoteEBegin-->If a fault occurs due to a sensor then the ABS ISN'T allways deactivated as my sensor went the light came on then went out but when i put my foot on the brake i could here the ABS letting off on that wheel and it made it hard for me to stop.<!--QuoteEnd--></div><!--QuoteEEnd-->
That's what happened to me too, Scary!
My cars have all had a special braking system... HIBCS...
(Human Interactive Braking Control System)
Congratulations on MOT Pass!
ice man
Can prevent accidents, but agreed can also contribute towards them.
My wife was in a shunt in he 05 Meriva - in the wet. A pedestrian jumped out onto a zebra crossing, the car in front did an emergency stop, the wife hit the brakes, and also a drain cover. ABS kicked in, Missus couldnt retreive it and without locking up, she 'rolled' into the car in front, with the ABS pulsing and pushing against the brake pedal. She said if the ABS hadn't been interfering she would have stopped in time.
ABS is more useful at higher speeds, IMHO.
ice man
<!--QuoteBegin-billys valver+--><div class='quotetop'>(billys valver)</div><div class='quotemain'><!--QuoteEBegin-->[PHP][/PHP] and abs doesnt stand for anti lock braking system, its advanced braking system, [PHP][/PHP]
i think you will find that, A.B.S does stand for anti lock brake system<!--QuoteEnd--></div><!--QuoteEEnd-->
mercedes inveted abs and they called it advanced braking system, yet somehow it started gettin called anti lock.
houston
<!--QuoteBegin-RobbieV+--><div class='quotetop'>(RobbieV)</div><div class='quotemain'><!--QuoteEBegin-->The last post on the subject (from me :icon_mrgr ) before the handbags appear
<a href="http://www.whnet.com/4x4/abs.html" target="_blank">http://www.whnet.com/4x4/abs.html</a><!--QuoteEnd--></div><!--QuoteEEnd-->
as i said Anti lock Brake System
i me too!
i me too!
billys valver
i have a disabled relation myself, did you ever think that?
its all in humour, he was the one who sent me that pic ffs!
have i done summit to you before or summit? how many times have you bit at my posts in this thread?
i speak my mind, sorry if that offends but im not gonna change any time soon.
houston
Oh Bugger - I hope No-ones going to be upset with me. Upon removing my 140 clocks to instal my new 160 clocks I noticed the ABS bulb missing!
I know there's a fault - there's bound to be.
Dilema is do I take out the bulb on the new dash and remove the ABS fuse, Or do I leave the bulb in and Add another Job to next months MOT list?
Wish I never looked now!
If I take the bulb out on the new clocks will anyone mind?
ice man
houston
No ABS light will fail the MOT for any car fitted with ABS, AND it must follow the correct extinguishing sequence. All MOT centres have a big chart listing all cars fitted with ABS and their "time to extinguish" the warning light and whether the ignition needs to be turned on etc etc. An MOT tester will refer to this chart if hes doing his job and spot any bodging with oil pressure lights etc (and he will be well aware of this one,its as old as ABS itself). Like it or not its part of the brake system and part of the MOT to test the operation of the warning light. You might get away with it but........
foxxy
<!--quoteo--><div class='quotetop'></div><div class='quotemain'><!--quotec-->he will be well aware of this one,its as old as ABS itself<!--QuoteEnd--></div><!--QuoteEEnd-->
luck of the draw really, mine passed, any other time it could have failed.
but my sensor arrived today, fittin it tomorrow cos im off work.
houston
Users browsing this forum: Bing [Bot] and 30 guests
