Quick Sunroof question....
by noelboy » Wed Aug 31, 2005 4:16 pm
My sunroof has 2 stages of being open,
so if I hold the button it will move 3/4 of the way back, then I have to re-press the button and it'll continue moving back.
Why is this?
noelboy
by icewizard » Wed Aug 31, 2005 4:30 pm
Sounds to me like the gears/switches in the sunroof motor are mis-aligned.
The sunroof should pause after it's fully tilted up not halfway through sliding back.
Could be a pain in the a8rse to solve though.
icewizard
by mrsounds » Sun Sep 11, 2005 1:22 pm
when i got my calli sunroof didnt work cos alignment was shot! how i fixed it was make sure roof is closed unbolt sunroof motor hold it up but away from gearing! and get someone to to push the sunroof switch on the closed switch! then i bolted motor back into postion! then u should get tilt on ur fist hold then hold again for open! well it worked for me lol was a bit awkward cos had to work with back seat down and rear of headlinner uncliped!
hope that helps
lee
mrsounds
