*urgent* Alternator Fault Maybe
Cheater, cheers for the advice but its still blowing the fuse
right symptoms:
Fuse number 2 keeps popping (speedo and cigerette fuse) this in turn causes the battery light to come on!!
this seems to happen when i rag the car (not reving but driving fast)!!
tried putting a 30amp fuse in (only one i had) and now the battery light is on constantly and seems to flutter a bit!!!! also the fuse gets REAL hot!!!
so the volt reader reads a steady 14volts or whatever and seems to be working ok.....now is the alternator knackered or could this be something else.
whats the best way to test.
16v Redtop L Reg
Rob
right symptoms:
16v Redtop L Reg
Rob
Robert_Dale
rob ,
when i joined clubcalibra .com (cough!!) my alternator died one night just as i was getting back from the chippy ,it turned out i had to get an reconditioned one for £90 approx as (manfred had told me a diode had burnt out and as it turns out he must of been right cos the new one has been great for the last 2 yrs
