Powerflex bushes, camber correction
by Cheater2k » Thu Aug 18, 2005 4:05 pm
On your car yeah mate, your camber would be out [img]/tongue.gif[/img] big tyres and suspension
but somone who hasnt got big wheels or suspension, should have normal camber.
Prob take an hour if you have no problems, prob take anyone whos laid back a few hours though, rofl
Cheater2k
by joeraz » Thu Aug 18, 2005 5:08 pm
<!--QuoteBegin-Cheater2k+--><div class='quotetop'>(Cheater2k)</div><div class='quotemain'><!--QuoteEBegin-->If its not lowered, and the cambers out, theres somthing else wrong mate, so your missing the point completly.
Its either your wishbones, or suspension struts, maybe even a suspension spring snapped.
Check all these first.<!--QuoteEnd--></div><!--QuoteEEnd-->
wheels ET35mm
joeraz
by Welsh_Andy » Thu Aug 18, 2005 5:37 pm
<!--QuoteBegin-Cheater2k+--><div class='quotetop'>(Cheater2k)</div><div class='quotemain'><!--QuoteEBegin-->On your car yeah mate, your camber would be out [img]/tongue.gif[/img] big tyres and suspension
Prob take an hour if you have no problems, prob take anyone whos laid back a few hours though, rofl<!--QuoteEnd--></div><!--QuoteEEnd-->
so i need a camber ajustment set for the front? how much u reckon that set me bk
Welsh_Andy
by Cheater2k » Fri Aug 19, 2005 12:24 pm
Not on the front, the front, its always the back which just suffers.
So just the rear camber correction kit.
Cheater2k
by Welsh_Andy » Fri Aug 19, 2005 1:47 pm
<!--QuoteBegin-Cheater2k+--><div class='quotetop'>(Cheater2k)</div><div class='quotemain'><!--QuoteEBegin-->Not on the front, the front, its always the back which just suffers.
So just the rear camber correction kit.<!--QuoteEnd--></div><!--QuoteEEnd-->
but its my fronts that are wearing on inside,so would need both front and bk in that case i think
Welsh_Andy
by Cheater2k » Mon Aug 22, 2005 12:05 pm
If its your front, get your laser tracking place to adjust yout toe (thats all ive done to the front of mine and it handles **** loads better and doesnt wear at all)
I do need to fix the camber on the back (17inch wheels, lowered 30-35mm on irmscher springs and its out 2-3 degrees)
Im planning on useing the kit Cav16 has on his site.
Cheater2k
by daddycool » Mon Aug 22, 2005 5:13 pm
<!--QuoteBegin-Cheater2k+--><div class='quotetop'>(Cheater2k)</div><div class='quotemain'><!--QuoteEBegin-->Im planning on useing the kit Cav16 has on his site.<!--QuoteEnd--></div><!--QuoteEEnd-->Do you have a link please?
daddycool
by Welsh_Andy » Mon Aug 22, 2005 7:10 pm
<!--QuoteBegin-Cheater2k+--><div class='quotetop'>(Cheater2k)</div><div class='quotemain'><!--QuoteEBegin-->If its your front, get your laser tracking place to adjust yout toe (thats all ive done to the front of mine and it handles **** loads better and doesnt wear at all)
call me dull wtf is my toe(and dont say on me foot)[img]/biggrin.gif[/img]
Welsh_Andy
by joeraz » Mon Aug 22, 2005 7:20 pm
lol,, but as far as i know, your "toe" is acctually nothing to do with your camber but it could wear the inside off your tyres,, but you would then want it "toed out" ,, have you had your car "aligned" ,, as in are your wheels both pointing forward when your steering is centered,, u know what i mean,,
im sure its your tie rods which are adjustable for the alignment you need,,
i have been driving now for 9 years and i have never had a car alighned, lol,, but with this cally i will hav it done
joeraz
by Cheater2k » Mon Aug 22, 2005 8:06 pm
<a href="http://www.ozebiz.com.au/racetech/theory/align.html" target="_blank">http://www.ozebiz.com.au/racetech/theory/align.html</a>
[img]/wink.gif[/img]
Cheater2k
by Welsh_Andy » Mon Aug 22, 2005 8:28 pm
<!--QuoteBegin-Cheater2k+--><div class='quotetop'>(Cheater2k)</div><div class='quotemain'><!--QuoteEBegin--><a href="http://www.ozebiz.com.au/racetech/theory/align.html" target="_blank">http://www.ozebiz.com.au/racetech/theory/align.html</a>
[img]/wink.gif[/img]<!--QuoteEnd--></div><!--QuoteEEnd-->
well fook me,learm summit new everyday
Welsh_Andy
by Cheater2k » Mon Aug 22, 2005 9:37 pm
<!--QuoteBegin-joeraz+--><div class='quotetop'>(joeraz)</div><div class='quotemain'><!--QuoteEBegin-->lol,, but as far as i know, your "toe" is acctually nothing to do with your camber but it could wear the inside off your tyres,, but you would then want it "toed out" ,, have you had your car "aligned" ,, as in are your wheels both pointing forward when your steering is centered,, u know what i mean,,
i have been driving now for 9 years and i have never had a car alighned, lol,, but with this cally i will hav it done<!--QuoteEnd--></div><!--QuoteEEnd-->
actuly yeah, i took mine to demon tweeks on saturday, they recommended me to alter the toe on the frnt to stop tyre wear and advised me to find a solution for the rear camber (as they were not sure who make the camber kits)
Cheater2k
by daddycool » Mon Aug 22, 2005 11:07 pm
FRONT:
'Toe in' and 'toe out' (commonly called 'tracking') is adjusted by means of the track rod ends of the steering rack.
Camber is non-adjustable*
Castor is non-adjustable*
REAR:
Toe is non-adjustable*
Camber can be adjusted with the correct bushes.
*Although these settings are normally non-adjustable they CAN be changed by drilling, welding or making of custom bushes and spacers, etc.
daddycool
by Cheater2k » Wed Aug 24, 2005 10:49 am
<!--QuoteBegin-daddycool+--><div class='quotetop'>(daddycool)</div><div class='quotemain'><!--QuoteEBegin-->Do you have a link please?<!--QuoteEnd--></div><!--QuoteEEnd-->
<a href="http://www.cav16.co.uk/camberkit.pdf" target="_blank">http://www.cav16.co.uk/camberkit.pdf</a>
Cheater2k
by joeraz » Wed Aug 24, 2005 6:16 pm
<!--QuoteBegin-Cheater2k+--><div class='quotetop'>(Cheater2k)</div><div class='quotemain'><!--QuoteEBegin--><a href="http://www.cav16.co.uk/camberkit.pdf" target="_blank">http://www.cav16.co.uk/camberkit.pdf</a><!--QuoteEnd--></div><!--QuoteEEnd-->
ok, sold, were do i buy?
lol, the callys costing me heaps this month, £700 and rising, still got to get the clutch an intercooler fitted plus MOT so im thinking at least £1500 :eek: i hate the fact im keeping a note of spending,, ekk,, it ads up
joeraz
