Wishbones
Looks like just 3 bolts to undo......
Gonna be a hard job then!!!
Undo the lower ball joint nut then hit the part of the hub where the stud goes through with a large hammer, whilst applying downwards pressure to the lower arm. You should hear the tone change when you hit it as the lower arm free's off from the hub.
Then just undo the other two bolts slide the arm out and refit the new one.............
I used to own this Calibra...
I now own this one.
Xbox live gamertag IcedSage
I now own this one.
Thinking of getting the wishbones from <a href="http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=4566377733&rd=1&sspagename=STRK%3AMEWA%3AIT&rd=1" target="_blank">here</a> dont seem like a bad price plus they come with all the bushes, balljoints and sleeves [img]/smile.gif[/img]
That looks to be a pretty good price! I bought new ones from Camberley Auto Factors in Basingstoke a couple of weeks ago. They cost me about £24 IIRC but that's each, not for the pair. Might be worth a look if you wanted them urgently though Rob, not too much more when you factor in the postage saving! [img]/smile.gif[/img]
BenW
daddycool
<!--QuoteBegin-daddycool+--><div class='quotetop'>(daddycool)</div><div class='quotemain'><!--QuoteEBegin-->The turbo ones were an uprated item. Not sure about the V6.
Best to check it out though.<!--QuoteEnd--></div><!--QuoteEEnd-->
Si, found this in the Haynes manual -
There was a change in the design of the lower arm in mid - 1993, with a strengthening flange along the seam on the forward facing side of the arm and a modified inner profile. The new design gives greater strength to the area around the front pivot bolt.
Ive check with the Ebay seller and these are the uprated ones.
thanks for the reminder [img]/smile.gif[/img]
Users browsing this forum: No registered users and 61 guests
