sizes of bolts needed
by wilza0 » Sun Jul 24, 2005 5:35 pm
went to do my how to and came accross a problem what size is the hub bolt on the front and what size is the caliper allen key bolts to take off the calliper all front related cheers guys
wilza0
by Blossey » Sun Jul 24, 2005 5:46 pm
I assume you mean the hub nut? Don't ask why I have one sat next to my computer but you'll need a 30mm spanner to remove it (from the hub, not from my PC).
Blossey
by wilza0 » Sun Jul 24, 2005 6:00 pm
cheers blossey now i just need to know how to get the front caliper off what size allen key do i need
wilza0
by ROG » Sun Jul 24, 2005 6:58 pm
i woudnt use std allen keys, ive never got the calipers off with them, get a set of allen key `sockets` that go on a 3/8 or 1/2" breaker bar, im not sure on the size but it`l be in a set and there about 10 pound in the halfords
ROG
by wilza0 » Sun Jul 24, 2005 7:12 pm
cheers rog
wilza0
by dj_smurph » Sun Jul 24, 2005 7:19 pm
front caliper is 7mm remembered that cause when i needed one the shop was sold out
dj_smurph
by Fraz » Sun Jul 24, 2005 7:32 pm
that is the size for the caliper , the one that holds the actual carrier for the caliper is 10mm ( if your removing the full thing)
by Tim2001 » Sun Jul 24, 2005 7:54 pm
Was gonna say 10 mm as well best if you have some sort of impact wrench as these can be a bit of a pain to undo iirc
Tim2001
by wilza0 » Sun Jul 24, 2005 9:09 pm
ah it will be ok in the end got some good pics already when i get the bits i need i will be on my way to lowering the project is starting to become fun.
wilza0
