Removing locking wheel bolts
Does anyone know of either a way of removing locking wheel bolts or where i can take my car to have them removed in Liverpool, i used the free set that came with my wheels and now the key has rounded off and i cant take them off!
the wheel bolts are the type with a hardend steel collar, so you cant hammer a socket on.
ROG
<!--QuoteBegin-jaybv6+--><div class='quotetop'>(jaybv6)</div><div class='quotemain'><!--QuoteEBegin-->buy some locking wheel nut removers.<!--QuoteEnd--></div><!--QuoteEEnd-->
Are these the things that 'thread' the nut in reverse, allowing you to unscrew the nut?
If it is they only work on certain locking nuts.. even the bloke in the shop i went to adviced me against them!!
Dawson16v
C20XE - Possible Porous Head - Help Please, Gutted
Had the same prob had to chisel of the colar use a smaller socket and an impact wrench with a big hammer mind your wheels though.
I it was not for bad luck i'd have no luck at all
Rog,
How are ya mate, finally another member in Liverpool. I no a local garage that would have got your wheels off but your sorted now so if there is anything else i can help you with let me no. I no a few mechanics, a couple are mobile too so if you need your clutch doing at home drop me a line and i,ll see what i can do for ya mate. We,ll have to arrange a meet when you get your car sorted
Cheers Fella.
Cheers Fella.
sparky2004
sparky2004, The clutch is on a turbo, i was going to do it myself but after changing a gearbox on a 8v last week im not going to do this one, not that its difficult it just takes too long! being 4x4 theres even less room and many more bits!, everybody says to get it done by vts who ive asked. All the gerbox places charge the same or more, vts can arrange to pick it up and fix it and get it brought back!., were abouts in liverpool are you.
ROG
