I want to fit some lights under bonet???
by splinter » Fri Jan 16, 2004 3:46 am
But where can i find the wires that go to the under bonet light ???
Mine did not come with one as standard.
Thanks.
by DAN » Fri Jan 16, 2004 5:17 pm
Didnt know that you could get a light as standard :?
What sort of lights you looking for, neons or a service light?
Cant you just run it off the battery, ground off the bodywork and put a switch in between?
cheers
DAN
by splinter » Fri Jan 16, 2004 5:23 pm
Well yes i could do that but i want them to come on when i open the hood.
The lights ive got are blue led ones.
And yes some do come with them as standard , mine has the hole for the light but i cant find the wires???
by Fraz » Fri Jan 16, 2004 6:05 pm
Ian the wires wont be there for the light ...I looked everywhere for them on mine as I fitted the heated washer jets (have no idea what I need them for though [img]/biggrin.gif[/img] ) on mine which also had the light connections on the same loom. Checked the diagram and it seems the power supply comes form the headlight washer relay..which was only on the very early cars
what I would do is find a switch like they use on the boot or doors (also some alarms) find a constant live and take that to the light then use the switch to supply the earth ..should work fine
by splinter » Fri Jan 16, 2004 6:24 pm
Ok thanks fraz.
I might just make a ****** then , might be easy that way.
Bank account sorted...
by Admin » Fri Jan 16, 2004 6:30 pm
I seem to recall for the OE under bonnet light to work, the lights (Sidelights at least) had to be turned on.
Admin
by leegsi » Fri Jan 16, 2004 6:46 pm
The under bonnet light comes on when the lights are on or past the sidelight setting.
Its on even if the bonnet is closed
leegsi
by splinter » Fri Jan 16, 2004 6:55 pm
Ohh right i will just make some sort of ****** up then.
Bugger.
I wanted evrything right. :cry:
by leegsi » Fri Jan 16, 2004 7:09 pm
If you dont use the alarm plunger by the alarm horn then just use that to turn them on and off.
Live to the sidelight live and earth through the plunger
leegsi
calibra guage holder for drivers airvent
by splinter » Fri Jan 16, 2004 7:16 pm
I was sitting here just thinking of the same thing Lee.
Great minds think alike ha..
And yes it is used for the alarm.
So is it a live or neg on the rubber s*itch.
And why is it that when i write sw*tch it blanking it? hahahahaha
SW*TCH IS NOT SWEARING is it???
by skellem » Fri Jan 16, 2004 7:52 pm
switch
skellem
by skellem » Fri Jan 16, 2004 7:53 pm
It's OK, what you on about??? [img]/smile.gif[/img]
skellem
by splinter » Fri Jan 16, 2004 7:59 pm
Hahahahahahaha Very funny. [img]/biggrin.gif[/img]
by Tattooman » Wed Feb 11, 2004 12:13 am
Tattooman
Hi
by splinter » Wed Feb 11, 2004 12:43 am
YER somthing like that. ... but not at the cost.lol
