Stereo Dead
Stereo Dead
by Gandalf » Sun Feb 13, 2005 8:59 am
I pulled my cd player out yesterday to sort my speakers out and one of the power connectors (yellow) must have come out (red/black/yellow are on their own block connector) I put it back and checked the others but no joy, I tried an old stereo too, but that was also dead, I assume the yellow wire touched something and blew a fuse, anyone know which one it's likely to be and how to tell? all my car electrics seem fine
thanks
Mike
Gandalf
by Paul » Sun Feb 13, 2005 10:13 am
I'd try fuse 8 first mate. It's a 15Amp one.
You should be able to see if it's blown. If you can't, just swap it with fuse 7.
If your indicators and brake lamps stop working, then the fuse is blown.
Paul
by Gandalf » Sun Feb 13, 2005 10:20 am
Put fuse 8 in 7 and the indicators stopped working, off to halfords then?
Gandalf
by Paul » Sun Feb 13, 2005 10:35 am
Yep, fraid so mate.
I'd buy a selection and keep handy.
Paul
by Gandalf » Sun Feb 13, 2005 11:24 am
Put a new fuse in slot 8, still no power [img]/sad.gif[/img]
Gandalf
by Gandalf » Sun Feb 13, 2005 11:31 am
also changed 10amp fuse in cd player - no power
Gandalf
by andy69 » Sun Feb 13, 2005 12:24 pm
<!--QuoteBegin-Gandalf+--><div class='quotetop'>(Gandalf)</div><div class='quotemain'><!--QuoteEBegin-->also changed 10amp fuse in cd player - no power<!--QuoteEnd--></div><!--QuoteEEnd-->
Is the earth ok?
andy69
by Paul » Sun Feb 13, 2005 1:14 pm
Check fuse 2, (20amp) and fuse 9 (10amp)
Paul
by sofaman » Sun Feb 13, 2005 4:42 pm
here are 2 pics of the connector block - see if they match up
<a href="http://www.sofaman.co.uk/cali/wire1.jpg" target="_blank">http://www.sofaman.co.uk/cali/wire1.jpg</a>
<a href="http://www.sofaman.co.uk/cali/wire2.jpg" target="_blank">http://www.sofaman.co.uk/cali/wire2.jpg</a>
hth
sofaman
by Gandalf » Sun Feb 13, 2005 6:07 pm
replaced 2 and 9, still no luck [img]/sad.gif[/img]
Gandalf
by Paul » Sun Feb 13, 2005 6:12 pm
Have you got access to a multi-meter?
It'd be handy to see if you have any voltage on either the red or yellow wires.
Paul
by Gandalf » Sun Feb 13, 2005 6:42 pm
I'll take it to my mate tomorrow he has a live tester, It was working fine but the cd player kept turning off at high volume because the previous owner had wired the speakers wrong, as i say when i took it out i noticed the yellow wire had come out of the block connector, since then nothing even with a totally different cd player
Gandalf
