Someone knows that?
Someone knows that?
by Dorca » Mon Aug 24, 2009 4:39 pm
Hi, anyone know what function pin that can be placed in A or B?.
Thanks
Dorca
Re: Someone knows that?
by RobbieV » Mon Aug 24, 2009 4:42 pm
by Dorca » Mon Aug 24, 2009 8:11 pm
RobbieV wrote:http://www.topbuzz.co.uk/info/fault_codes/fault_codes.htm
Thank you, but I talk about this:
Dorca
by Callyman » Mon Aug 24, 2009 8:18 pm
by RobbieV » Mon Aug 24, 2009 8:18 pm
by yellow calibra » Mon Aug 24, 2009 8:28 pm
is that not the plug that tells the ecu what fuel your puting in
yellow calibra
by Dorca » Mon Aug 24, 2009 8:44 pm
Thank you
Dorca
by Callyman » Mon Aug 24, 2009 8:55 pm
Beat ya Rob 8) hehe
by RobbieV » Mon Aug 24, 2009 9:05 pm
callyman wrote:Beat ya Rob 8) hehe
Not if i delete your post :twisted:
by Allys Cally » Mon Aug 24, 2009 9:14 pm
your scared to do it MrV, that would be seen as abusing your moderaters privalige's.
but do it for a laugh anyway :lol:
by RobbieV » Mon Aug 24, 2009 9:29 pm
Nah i'll let have this one ..................... but not the next time :twisted:
by Callyman » Mon Aug 24, 2009 9:58 pm
Bloody Mods. :roll: :lol:
by Dorca » Mon Aug 24, 2009 10:05 pm
Faster and furious people.... 8)
Dorca
by frankej » Mon Aug 24, 2009 10:42 pm
:laughing-rolling: :obscene-tolietclaw:
frankej
by Dorca » Thu Aug 27, 2009 9:42 pm
NOT carry an octane selector. These engines automatically adjust the ignition curve, taking it as late as possible, almost at the limit of the dive. This will get bitten by a sensor, so that the ECU makes the following loop: the ignition is advanced until it begins to itch> is detected by the sensor immediately chopped goat is the ecu> This slows the ignition> chopped sensor squeal stops> immediately advances the ignition ecu> etc ... etc ... etc ...
The 16v lead a pin A / B on the same site as the 8v octane, but with different functions. The function of this pin is to adjust the levels of CO and noise to the stringent German standards ... Standard is in position A, the "restricted", the best position for this pin, obviously, is the B
RON plug that you use in your 8v?
As I assume you may know, this pin is located in the upper right of the engine compartment. In our calyx of up to 92, with a 90% chance will be yellow, showing "95" and "91", and will be placed so that the indication "95" is visible. It serves to tell the motor octane of gasoline that we have and adjust the ignition timing. With the pin in 95 we refuel "unleaded" 95 octane or more (never less or mischievous crank ...)
This information is from "master" Tropic (teamcalibra026.es)
Dorca
Users browsing this forum: Google [Bot] and 13 guests
