Someone knows that?
Someone knows that?
Hi, anyone know what function pin that can be placed in A or B?.
Thanks
Thanks
Dorca
Re: Someone knows that?
RobbieV wrote:http://www.topbuzz.co.uk/info/fault_codes/fault_codes.htm
Thank you, but I talk about this:
Dorca
That's the RON plug.
So look here http://www.topbuzz.co.uk/info/ron_plugs/ron_plugs.htm
is that not the plug that tells the ecu what fuel your puting in
yellow calibra
callyman wrote:Beat ya Robhehe
Not if i delete your post
RobbieV wrote:callyman wrote:Beat ya Robhehe
your scared to do it MrV, that would be seen as abusing your moderaters privalige's.
but do it for a laugh anyway
Nah i'll let have this one ..................... but not the next time
Bloody Mods.
callyman wrote:RobbieV wrote:callyman wrote:Beat ya Robhehe
Bloody Mods.![]()
Faster and furious people....
Dorca
Bloody Mods.![]()
frankej
NOT carry an octane selector. These engines automatically adjust the ignition curve, taking it as late as possible, almost at the limit of the dive. This will get bitten by a sensor, so that the ECU makes the following loop: the ignition is advanced until it begins to itch> is detected by the sensor immediately chopped goat is the ecu> This slows the ignition> chopped sensor squeal stops> immediately advances the ignition ecu> etc ... etc ... etc ...
The 16v lead a pin A / B on the same site as the 8v octane, but with different functions. The function of this pin is to adjust the levels of CO and noise to the stringent German standards ... Standard is in position A, the "restricted", the best position for this pin, obviously, is the B
RON plug that you use in your 8v?
As I assume you may know, this pin is located in the upper right of the engine compartment. In our calyx of up to 92, with a 90% chance will be yellow, showing "95" and "91", and will be placed so that the indication "95" is visible. It serves to tell the motor octane of gasoline that we have and adjust the ignition timing. With the pin in 95 we refuel "unleaded" 95 octane or more (never less or mischievous crank ...)
This information is from "master" Tropic (teamcalibra026.es)
Dorca
Users browsing this forum: Majestic-12 [Bot] and 19 guests
