The dreaded click from the sunroof
As the title says, opened the sunroof this morning it raised up as normal but then when click :sob:
Now it wont close or slide back.
Will have to wait tilll i get home to use the manual tool.
So will i be lucky and just the cable sprung loose or will it be something esle?
Anyone got any solutions to how to look or do i need to drop the roof lining no matter what?
cheers in advance
Will
cheers in advance
Will
WillsToy
Bugger got home tried the crank handle that was in my handbook and guess what it's the wrong type...it dosent fit!!!!! s**t
And it looks like i may be lucky as the motor feels loose and moves around abit.
Looks like i may have to take the headlining down sooner than i thought now.
Did a search on sunroof problems, many thanks to wilkybar kid as his headling guide will be useful.
Nearly 9pm now, shall i start stripping it off or wait???
Forecast for rain tomorrow...eekkk
Will
Will
WillsToy
MJ
Cheers for the info guys, took less than an hour for me to solve.
Manage to tighten the bolts the hold the motor up all were a little bit loose, one almost fell out.
Didnt even have to drop the headlining, was able to get at the motor after removing the sunroof trim and using a stumpy crosshead.
Only thing i had to do was open the sunroof fully with the crank handle to reset the switch so to speak, otherwise the roof wasnt fully shut when just using the button.
I think Animal describes it better in one of the sunroof old threads
Will
Will
WillsToy
