The dreaded click from the sunroof
by WillsToy » Tue Oct 03, 2006 10:16 am
As the title says, opened the sunroof this morning it raised up as normal but then when click :sob:
Now it wont close or slide back.
Will have to wait tilll i get home to use the manual tool.
So will i be lucky and just the cable sprung loose or will it be something esle?
Anyone got any solutions to how to look or do i need to drop the roof lining no matter what?
cheers in advance
Will
WillsToy
by Robs-se » Tue Oct 03, 2006 11:22 am
i have a feeling you may have to drop the lining. can't see any other way in.
Bummer :cry: . hope it doesn't rain on you
Rob
by WillsToy » Tue Oct 03, 2006 12:43 pm
Midday and the black clouds are gathering......
Cheers for the info Rob, guess i'm dropping the roof lining at the weekend :frown:
Will
WillsToy
by WillsToy » Tue Oct 03, 2006 8:52 pm
Bugger got home tried the crank handle that was in my handbook and guess what it's the wrong type...it dosent fit!!!!! s**t
And it looks like i may be lucky as the motor feels loose and moves around abit.
Looks like i may have to take the headlining down sooner than i thought now.
Did a search on sunroof problems, many thanks to wilkybar kid as his headling guide will be useful.
Nearly 9pm now, shall i start stripping it off or wait???
Forecast for rain tomorrow...eekkk
Will
WillsToy
by MJ » Tue Oct 03, 2006 9:31 pm
ive never looked but I thought that the "crank handle" for sunroof over ride was the wheelbrace?
MJ
by Rusty_CallyT » Tue Oct 03, 2006 9:37 pm
theres a special tool for it, a lot smaller than a wheel brace.
if you have a decent allen key that'd probably do the job
Rusty_CallyT
by MJ » Tue Oct 03, 2006 9:43 pm
oh, just aswell ive never needed it I guess, but worth knowing ta ..... i'll have a look tomorrow [img]/smile.gif[/img]
MJ
by Animal » Tue Oct 03, 2006 10:27 pm
I remember fixing mine, it only took a couple of hours. That was not rushing it.
by WillsToy » Mon Oct 09, 2006 3:27 pm
Cheers for the info guys, took less than an hour for me to solve.
Manage to tighten the bolts the hold the motor up all were a little bit loose, one almost fell out.
Didnt even have to drop the headlining, was able to get at the motor after removing the sunroof trim and using a stumpy crosshead.
Only thing i had to do was open the sunroof fully with the crank handle to reset the switch so to speak, otherwise the roof wasnt fully shut when just using the button.
I think Animal describes it better in one of the sunroof old threads
Will
WillsToy
by BazV6er » Mon Oct 09, 2006 4:13 pm
i try not to open the sunroof in these up and coming mths ,only spring and summer but thats not to say it will go god for bid ...glad you got it fixed
by Oakey22 » Thu Oct 19, 2006 10:50 am
It normally clicks out of place because those bolts have come loose, did you use thread-lock on the nuts?
Oakey22
by Chavtastic » Thu Oct 19, 2006 11:24 am
Oh ****. I hate working with headlining, it never goes back up properly!
by Oakey22 » Thu Oct 19, 2006 3:36 pm
its easy ben, just take off the bits and bobs and get someone to help you put it back up otherwise it will fold up.
Oakey22
