Afterburner ABS problem
by se6 » Sat Feb 25, 2006 4:53 pm
Today i fitted my afterburners using the interface so that they are legal. I have a problem in that when i have the lights on the ABS light will come on leaving me with no ABS, if they are off however the ABS works fine (obviously after restarting the engine so that the ABS is rechecked) These are my checks to see what situations ahd which result.
Both afterburner clusters- lights off = ABS, lights on = no ABS
Both original clusters- ABS
No clusters at all- No ABS
Left Afterburner + right original- ABS
Right Afterburner + left original- ABS
Left afterburner only- No ABS
Right afterburner only- No ABS
Left original- ABS
Right original- ABS
Both afterburners is the only situation where the ABS being on or off is dependent on the lights being on or off. When the lights are off the ABS works, as soon as the lights are switched on the light on the dash appears and the wheels will lock up under hard braking.
All functions of the lights are working (indicators, reverse, fog, brake lights with lights off, brake lights with lights on)
As i have used old light plugs to wire them up, on the left Afterburner the redundant wire is the fog light wire (not connected to interface). And on the right hand cluster it is the reverse wire left unused.
Any ideas at all anyone????
Regards David
by gran » Sat Feb 25, 2006 5:53 pm
ABS or check light do you mean?
gran
by daddycool » Sat Feb 25, 2006 9:45 pm
Hi David,
I've not had chance to check the circuit yet, but let me assure you that if we can't sort the problem out over the phone/internet I will gladly have your interfaces back and test them out to see if they are at fault.
I have sold more than thirty sets of Afterburner Interfaces and yours is the only one that exhibits this fault.
daddycool
by daddycool » Sat Feb 25, 2006 9:58 pm
Just had a thought....
You told me that your 'lamp check' connector is not plugged into your clocks.
What if the ECU is putting a voltage out to illuminate the 'lamp fail' light, but you have not got your lamp check circuit connected. Where is that voltage going? It could be travelling through the loom and causing problems with the ABS ECU.
One way to try this is to re-fit your OE light clusters and then remove a bulb to try to illuminate the 'lamp fail' light. If your ABS stops working, then that is what your problem is.
I'm sure it's got something to do with your lamp check circuitry.
daddycool
by Novaneil » Sat Feb 25, 2006 11:57 pm
Hello,
Im experiencing exactly the same problem (have done since about Christmas) When the lights are off, everything works fine and ABS works. But when I switch my lights on the ABS warning light on the dash fires up and I can lock the wheels up.
I to have the Afterburners with Interfaces. But to be honest it doesn't really bother me that much, although I would like to know why its doing it?
The only thing with mine is, is that the engine management light keeps on coming on as well, which I haven't had time to sort as a new engine is going in soon.
I thought I just needed a set of those Load resistor things, but by the sounds of it maybe not....
Neil
Novaneil
by se6 » Sun Feb 26, 2006 12:10 am
At least im not the only one!
I will have a play around with mine tomorrow and see if i can get any joy.
by Novaneil » Sun Feb 26, 2006 10:24 am
I don't know if it makes any difference but I see you have an 8v, mine too is an 8v... Could just be coincedence I know.
To be honest I actually prefer it without the ABS, as i've been used to Nova's without it for years. But i've heard a rumour that if the light is continually on it can upset the ECU...... don't know how much truth there is in this though???
Neil
Novaneil
by se6 » Sun Feb 26, 2006 7:54 pm
I have removed the interfaces now and the ABS works fine again, just no reverse light or fog light. How confusing.
by daddycool » Sun Feb 26, 2006 9:27 pm
It's got me foxed!
If you send them back to me I will test them to make sure everything is OK.
What I can't get my head round is.... If it's something to do with the interfaces, then how come removing the OE clusters causes an ABS fault?
BTW Martin on CC has an 8V and his interfaces work OK. So it's nothing to do with model.
daddycool
by karma1984 » Tue Feb 28, 2006 2:49 pm
I dont know if this is just coincidence but recently bought my cally with afterburners and ABS light is on, coukld it be a problem with the lights in general as they aren't standard, or is it just that my ABS is screwed, just thought id mention it!
karma1984
by daddycool » Tue Feb 28, 2006 6:46 pm
karma... do your lights have my Afterburner Interfaces fitted?
Are you sure it's the ABS light, not the 'lamp fail' light?
daddycool
by se6 » Wed Mar 01, 2006 8:35 pm
I shall send them back next week if i have no joy. I will be retesting this weekend, my mate is an electrician and thinks he may have some ideas as to what may be causing the problems, bad neutrals or something or other!
