I want to fit some lights under bonet???
<!--QuoteBegin-Murdomac+--><div class='quotetop'>(Murdomac)</div><div class='quotemain'><!--QuoteEBegin-->'Its on even if the bonnet is closed' is that like the one in the fridge?<!--QuoteEnd--></div><!--QuoteEEnd-->
Maybe that's why the OE bonnet light was so crap (or so I heard), if it's on even when the bonnet is closed they might have had the first underbody lightting effect with a bright bonnet lamp...
Leigh
Fridge lights only come on when you open the door...like your glove box light its controlled by a plunger type switch [img]/tongue.gif[/img]
As a cheap alternative you could wire up 3 sets of 3 LEDS in series on some circuit board and replace the bulb under your bonnet with this. I have done it and now my engine glows blue when I open the bonnet.
dazjb
I havent got a under bonet light, i have the place to put it, and was going to take the feed from the alarm plunger, but i cant find the live feed !!!
I will have to fit a ****** some where in the car to turn them on and off.
<!--quoteo--><div class='quotetop'></div><div class='quotemain'><!--quotec-->Checked the diagram and it seems the power supply comes form the headlight washer relay..which was only on the very early cars<!--QuoteEnd--></div><!--QuoteEEnd-->
Intersting! My under bonnet light doesn't work. Neither does the washers on the headlamps. Where's the relay kept then? I'll have to check it out.
Phil
