Roll call
Re: Roll call
by Callyman » Mon Dec 04, 2017 6:48 pm
Mark1 wrote:
rich30mex wrote:just looked at the first company i came across and its not cheap
That's not that bad but I don't think we have the funds to do it.
We've been good in the past at a whip round, we got our name on Redvictor for life (I do bits for them to ensure that), Became Founder members of the 5 second club AND Bought x2 Even shelters.
So, It's doable.
Re: Roll call
by HOT-ROD » Mon Dec 04, 2017 7:56 pm
Unfortunately I've not logged on for ages. I have had a massive amount of help from the club site but the sad fact is fb is easier to post and upload pics. I would prefer to only use the site because the info on here is more reliable unlike fb where the masses try and tell you the cause of your brakes being spongy is because your head gaskets gone! :lol:
Re: Roll call
by Cliff » Mon Dec 04, 2017 9:43 pm
Hey Hot-rod, I did make some enhancements for photo sharing and also, if you use Tapatalk (available for android and iOS) then you get a more “Facebook-like” experience including direct pic, video uploads, updates on posts, subscribe etc.
If there’s something more you’d like to see and/or you need help with Tapatalk - just shout and I will try my best.
Re: Roll call
by HOT-ROD » Mon Dec 04, 2017 9:55 pm
Cliff wrote:Hey Hot-rod, I did make some enhancements for photo sharing and also, if you use Tapatalk (available for android and iOS) then you get a more “Facebook-like” experience including direct pic, video uploads, updates on posts, subscribe etc.
Cheers will look in to that. If I'm honest I've always just shut that window down when it's asked if I wanted to use it. :lol:
Re: Roll call
by Phill » Tue Dec 05, 2017 11:44 pm
Hi cliff, when i look at a lot of the photos that have been posted i cant see the full picture, if there is lets say 5 photos then i will see a third of them, i then i have to scroll down to the bottom of the 5 photos and use the slide bar to move the rest of the pictures in to view. Can this be looked at or is it a setting i need to change in my control panel. thanks.
Re: Roll call
by Cliff » Wed Dec 06, 2017 1:24 pm
Hi Phill
What kind of device and which browser (including version) are you using?
Andrew
Re: Roll call
by DanSE4 » Wed Dec 06, 2017 4:50 pm
I still log in occasionally but as has been pointed out, FB is killing forums.
It's not just this one, it's all of them but it's never going to be like the pre-FB days as it's just more convenient to use no matter how mobile friendly a forum may be (TapaTalk can do one lol).
People will go where the people are, where the responses are & where it's most convenient. The only annoying thing is the amount of Calibra groups on FB, see the same thing posted about half a dozen times yet still seen by pretty much all the same people!
Calibra SE4 3.2 V6 + F28
A Couple of German Cars!
Re: Roll call
by Cliff » Wed Dec 06, 2017 10:09 pm
DanSE4 wrote:I still log in occasionally but as has been pointed out, FB is killing forums.
What don’t you like about Tapatalk, out of interest?
Re: Roll call
by Phill » Thu Dec 07, 2017 7:31 pm
Cliff wrote:Hi Phill
Andrew
Hi Andrew, I use a dell laptop and the browser is firefox version 57.0.1 (64 bit)
Re: Roll call
by Cliff » Thu Dec 07, 2017 7:58 pm
Andrew
Hmm, I wonder if its browser related - I tested with chrome, IE and Safari but not FF. I’ll try to set it up next week and test.
Re: Roll call
by rich30mex » Thu Dec 07, 2017 10:28 pm
If it helps I can tell you I use a Dell laptop too and mine is fine but I use chrome I do get the half pictures on my mobile but not too bothered
Phil could you not try chrome for a few days mate see if it solves it
Re: Roll call
by Phill » Fri Dec 08, 2017 8:50 pm
rich30mex wrote:If it helps I can tell you I use a Dell laptop too and mine is fine but I use chrome I do get the half pictures on my mobile but not too bothered
This is what i mean Rich and Andrew, this from cal16v wip same page. The first picture has the slide bar then on the same page the next photo is fine.
I'm not sure if it's the size of photo being uploaded, a setting i need to change or trying another browser like chrome.
Re: Roll call
by cal16v » Fri Dec 08, 2017 9:12 pm
Hi Phill,
Some (most!) of my pics are very large in size so I suspect this is what you are referring to. Perhaps the forum can be set up to reduce pic size to avoid the scrollbars? Or we could just upload the ideal pic dimensions if we knew the limits?
On a side note I cannot see the pics you've must have re-posted... this is a known change of service issue with photobucket afaik.
cheers
Re: Roll call
by cal16v » Fri Dec 08, 2017 9:13 pm
Hi Phill,
Some (most!) of my pics are very large in size so I suspect this is what you are referring to. Perhaps the forum can be set up to reduce pic size to avoid the scrollbars? Or we could just upload the ideal pic dimensions if we knew the limits? Keep in mind that with reduced pic size you loose a fair amount of detail...
cheers
Re: Roll call
by Phill » Fri Dec 08, 2017 9:26 pm
Hi Phill,
cheers[/quote]
That must be it bud as its not every photo. I was putting it out there incase there may have been a setting i could change to make all photos fit the page.
