Calibra v6 3.2 engine transplant
After years of searching have finally today took delivery of a Y32se, 3.2 engine from am omega elite covered a genuine 87000 miles would appreciate any advice on what's going to be involved.
Will post some pictures ASAP
- Gold Member
Re: Calibra v6 3.2 engine transplant
As said above, that's pretty much all there is to it (didn't need to swap the sump in my case as I fitted a Z32SE).
I also did thermostat, timing belt & waterpump while the engine was on a stand (so much more pleasant to do that way).
I did fit an F28 with mine though, never did get on with the F25 so if funding permits I thoroughly recommend it. There's a bit extra to do in order to accommodate the F28 & a few parts needed but I can provide details of that if that's something you're interested in.
Calibra SE4 3.2 V6 + F28
A Couple of German Cars!
Thanks for the advice not able to fit F28 as it's going into a rare Se9 auto Will post some pictures ASAP
- Gold Member
Typical, my mate has one for sale.
2 pedels II
- Gold Member
- Gold Member
- Gold Member
Got down to the oil cooler to find the reason the original car (Omega) was broken, failed oil cooler which i was informed of this problem when i originally bought the engine, pop a new one in problem solved.
Will be replacing both head gaskets, water pump, etc anyway
Got new GM water pump ready to be fitted, going to clean the thick mayo type substance left from the failed oil cooler
- Gold Member
That is a pig to clean up, good luck with it.
Washing powder works, we need it to Baz's V6 and it cleaned it all out.
Put it in the header tank when the engine is running and keep changing the water until it is clear.
Lol pmsl
Not going to get it all out until it's running and I know the engines out
- Gold Member
Sorry if I'm being a bit stupid or missed something but are you replacing a v6 with this one or is this in place of a 4 cyl?
