overhaul begins
Re: overhaul begins
by craigyboy » Sun Jan 13, 2013 5:23 pm
Thanks for that Fraz.For the windows can that just be doubled
up with the lock cable?
Re: overhaul begins
by Fraz » Sun Jan 13, 2013 6:14 pm
I would think the alarm would have a timed output just for windows ..if you use the lock it will be only a very short pulse so the window would only go up a wee bit ...not all the way
Re: overhaul begins
by craigyboy » Sun Jan 13, 2013 6:35 pm
Thats true.Oh well I dont think this alarm has this facility :doh:
Re: overhaul begins
by Fraz » Sun Jan 13, 2013 6:55 pm
what alarm is it
Re: overhaul begins
by craigyboy » Sun Jan 13, 2013 10:24 pm
its a E50 car alarm system .The make is Kodinis Raktas :whistle:
Got it off Ebay.It says on the box that one of the features is window
close output but I couldnt see it in the wiring diagram.I'll check it again
tomorrow.
Re: overhaul begins
by craigyboy » Wed Jan 16, 2013 11:29 pm
Fraz wrote:best place would be the central locking relay in the drivers kick panel
colours
lock is brown white
unlock is brown black
I think thats ocrrect but easy to check all you do is bare a wee bit and put an earth wire to the wire and see if it locks or unlocks
think the the window lift is also brown black if you want that to work as well ..sam ething works on a earth pulse
I checked the alarm earlier and the locking control wires are switching in positive
so I am going to have to add in two relays for the alarm wires to control the relays
and they can switch the two negatives to the central locking relay.
Oh the joys of buying from Ebay :doh:
Re: overhaul begins
by Fraz » Thu Jan 17, 2013 3:31 pm
would sell it and buy another as it sounds a load of rubbish ..I just fitted one of these does what I want. locks the doors and put the windows up
Re: overhaul begins
by craigyboy » Fri Jan 25, 2013 10:55 pm
Fraz wrote:would sell it and buy another as it sounds a load of rubbish ..I just fitted one of these does what I want. locks the doors and put the windows up
what make was the alarm you fitted Fraz?
Re: overhaul begins
by Fraz » Sat Jan 26, 2013 12:18 pm
seems I forgot the link ...its not an alarm
http://www.ebay.co.uk/itm/REMOTE-KEYLES ... 2326969f32
Re: overhaul begins
by craigyboy » Sat Jan 26, 2013 5:06 pm
Thanks for that Fraz,thats it ordered
Re: overhaul begins
by craigyboy » Sat Feb 16, 2013 7:09 pm
Thats the total closure system all working now and changed the
pump for the water scooshers today.Next job to get it mot'd and
get the bonnet resprayed
Re: overhaul begins
by calibre ray » Sat Feb 16, 2013 7:54 pm
it should be looking good when you get her finished bud.
Re: overhaul begins
by craigyboy » Thu Apr 18, 2013 10:08 pm
Quick update.fitted new H T leads to match
the rest of the engine bay
got interior completed,just needs cleaned
Heres how its looking now.Just needs motd and the bonnet resprayed
Re: overhaul begins
by Mark1 » Fri Apr 19, 2013 7:33 am
That's looking good
Re: overhaul begins
by rich30mex » Fri Apr 19, 2013 7:50 am
Looking well mate
