Fuel pump relay
Fuel pump relay
by craigyboy » Mon Dec 31, 2012 5:44 pm
Does anyone know where this is located on the ecotec?
I think the relay is Knackered
Re: Fuel pump relay
by v6 steve » Mon Dec 31, 2012 5:47 pm
drivers side kick pannel just under the ecu
Re: Fuel pump relay
by craigyboy » Mon Dec 31, 2012 5:49 pm
Cheers for that mate :handgestures-thumbup:
Re: Fuel pump relay
by Fraz » Mon Dec 31, 2012 7:09 pm
does the Ecotec not have two separate pinky relays rather than just the one black one ..seem to recall that
Re: Fuel pump relay
by craigyboy » Mon Dec 31, 2012 7:16 pm
Aye mate I noticed that when I took the kick plate off.
I'll change the two of them and see if that helps.
Re: Fuel pump relay
by craigyboy » Wed Jan 02, 2013 4:40 pm
Changed the two relays and the fuel pump in the tank
still not getting fuel to the engine.Anyone any ideas?
cheers.
Re: Fuel pump relay
by v6 steve » Wed Jan 02, 2013 4:52 pm
are you getting power at the tank ? or pressure in the rail
Re: Fuel pump relay
by craigyboy » Wed Jan 02, 2013 5:20 pm
v6 steve wrote:are you getting power at the tank ? or pressure in the rail
Ive disconnected the pipes and theres no fuel pumping out when trying
to turn it over so I dont think there is power getting to the pump.I tried
the pump before I installed it ,so I know its working ok.
Re: Fuel pump relay
by Fraz » Wed Jan 02, 2013 5:31 pm
yoou did reconnect the leads at the back that go to the fuel pump...easy done to forget them as your putting the tank back up
Re: Fuel pump relay
by craigyboy » Wed Jan 02, 2013 6:04 pm
Everything was put back the exact same way mate.
I'll give it another bash tomorrow
Re: Fuel pump relay
by v6 steve » Wed Jan 02, 2013 6:18 pm
have you checked fault codes could be the alarm mob has cut in
Re: Fuel pump relay
by craigyboy » Wed Jan 02, 2013 6:37 pm
Now theres a thing.
Anytime my alarm immobiliser kicks in it cuts out the starter motor
but its still turning! :think:
This is getting tricky!
Re: Fuel pump relay
by v6 steve » Wed Jan 02, 2013 6:47 pm
the blue turbo me and Ally had wouldnt start the starter would turn but no power at fuel pump it was the alarm, now dont ask how i fixed it as i didnt it was your mate that did youll would need to ask him it did only take him 2mins
Re: Fuel pump relay
by craigyboy » Fri Jan 11, 2013 5:46 pm
Ive bridged out the two relays and can hear the pump working
But ive noticed since the cars not started that the small buzzing
noise from under the bonnet has disappeared when the ignition is on
Could this be a burnt out solenoid? Ive checked all the fuses and theyre
all ok.Ive also checked the alarm and nothing seems to be connected to
the blue and red cable
Re: Fuel pump relay
by craigyboy » Sat Jan 12, 2013 9:24 pm
Anyone any ideas How to fix this?
