what fault do i have
im getting confused as i see a code that flashes number 5 after code 14 and then stops!
or have i got it wrong?
14 31 48??
what codes are flashing ...ty fraz for looking aswell
14 31 48??
Re: what fault do i have
First bud what engine so you have as the codes are different for each ecu.
Second have you looked on topbuzz for the codes? I will try and find the link for you.
callum-calibra
V6 and I know the link, just need conirmarion on the codes facing up
Starting from the beginning of your video this is what I can see...
Code 12 (three times)
Brief pause
Code 145 (three times) 145 Incorrect immobiliser signal received Faulty unit or break in wiring
Brief pause
Code 48 (three times) 48 Battery voltage Low voltage
Brief pause
Code 31 (three times) 31 Engine RPM signal (crankshaft sensor) No signal
Brief pause
Strange that it isn't flashing the separator code 12 in between the fault codes though, and I watched it a few times because I was expecting a '12' after the 145.
Brief pause
Brief pause
Brief pause
Brief pause
I used to own this Calibra...
I now own this one.
Xbox live gamertag IcedSage
I now own this one.
yup thats what I get no its the right way up ...did you charge the battery and do it again like I said to do ??
Users browsing this forum: No registered users and 55 guests
