headlights
headlights
by john.ness » Fri Aug 20, 2010 4:00 pm
does anyone know how to adjust the head lights as the beam is to high failed it on mot
john.ness
Re: headlights
by Robs-se » Fri Aug 20, 2010 4:07 pm
Haynes says there is a hole above the headlight that a screw driver can be inserted into and turn screw to adjust to required hight. have the headlight adjuster on dashboard set at 0
Re: headlights
by tazz666 » Fri Aug 20, 2010 4:08 pm
there is a knob on the hieght adjust motor on the back of the headlight :D
Re: headlights
by RobbieV » Fri Aug 20, 2010 4:12 pm
Why didn't the MOT man adjust it ?
The part arrowed needs to be turned anti clock wise.
Re: headlights
by tazz666 » Fri Aug 20, 2010 4:16 pm
aye that's the thing i was on about,
cause he was most probably a lazy git and couldny be bothered
Re: headlights
by john.ness » Fri Aug 20, 2010 4:47 pm
lol thats it he said the back springs are causing them to be high cos theyve collapsed i looked at back springs and there fine,so hes at it :naughty:
john.ness
Re: headlights
by Fraz » Fri Aug 20, 2010 8:15 pm
The hole in the top is for left to right adjustment ...the picture shows the bit to adjust the height
Re: headlights
by stevo turbo » Fri Aug 20, 2010 9:36 pm
on a mot your not allowed to adjust anything as far as im aware
Re: headlights
by James_Mould » Fri Aug 20, 2010 9:56 pm
An MOT tester is not allowed to change/ adjust anything on an MOT, even someting as simple as that or a blown bulb.
Most good garages call you for small things like that to get your permission to change them during the MOT to pass it.
Re: headlights
by RobbieV » Fri Aug 20, 2010 9:58 pm
stevo turbo wrote:on a mot your not allowed to adjust anything as far as im aware
That maybe so, best get yourself a decent MOT'er.
Re: headlights
by Callyman » Fri Aug 20, 2010 10:12 pm
I thought you could make adjustments within the testing period
Re: headlights
by meta05 » Sat Aug 21, 2010 8:45 pm
my local garage where i have been taking all my cars for the last 10 years has just changed the MOT tester to a young guy. the c**k has been a total a******e, he failed mine for headlight adjustment, really not the same service. not going back and i have told them so. sometimes when it comes rules some things can be sorted there and then and if they wont do it then they really are being anal about it. :evil:
meta05
Re: headlights
by john.ness » Mon Aug 23, 2010 4:49 pm
the guy ive been going to for 9 years always been fair till i took the cally in if the lights needed adjusted he wud do it there n then,i bumped into an old mate on sat i use to work with him in kwik fit hes still mot tester there i explained my situation with the calibra he said wen u have it ready he said take it down and leave it with me so gona do that!! :band:
john.ness
Re: headlights
by BazV6er » Thu Sep 16, 2010 2:27 pm
my guy at the mot place will always adjust it if he has to as he wudnt like to lose a good customer for something as small as that , he sorted me with a dodgy sidelight bulb he just said get yourself another one after he had put it through .been going down there 10 years + now
