ECU/Electrical problem ?
Re: ECU/Electrical problem ?
is it fixed now ???
arent the wire's going to the battery meant to be tight james
bigdaz1987
bigdaz1987 wrote:arent the wire's going to the battery meant to be tight james
is that what was up???hmn lol
k1nty
urm.... Yeah its fixed now. Shameful to admit that yes there was a loose wire to the battery...
Jamesyboy wrote:urm.... Yeah its fixed now. Shameful to admit that yes there was a loose wire to the battery...
not to worry James its happened to us all at some point, at least it was a simple fix
and to think you never wanted us to have a look at it there and then
I liked it going wrong, it kept me hidden under the car from the missus
its always the small things that make the diffrence
v6 steve wrote:its always the small things that make the diffrence
Indeed it is, took you all of 8 seconds to find it haha
tazz666 wrote:glad its all fixed mate
I bet, its not a faulty ecu.... again!!
and to think you wherent going to let us look
and it gave you good figures, it didnt seem to make much difference in mine, thats the only reason i pulled it out, i never made to the rr day down here , bloody gearboxes
tazz666 wrote:and it gave you good figures, it didnt seem to make much difference in mine, thats the only reason i pulled it out, i never made to the rr day down here , bloody gearboxes
It would have been interesting to actually do a test with it in and out, I think it makes it a wee bit more lively, i drove it for a few miles without and it felt proper pooh, i dunno what its set up to do, but it does make some difference.
i had both ecu's when i tried it and as i said mine felt just as quick with in or out
tazz666 wrote:i had both ecu's when i tried it and as i said mine felt just as quick with in or out
Oh so you dingied me with a dodgy chip
It is different i think, or its just my mind... lol
Jamesyboy wrote:tazz666 wrote:i had both ecu's when i tried it and as i said mine felt just as quick with in or out
Oh so you dingied me with a dodgy chip![]()
rpm limit will be increased atleast
k1nty
Users browsing this forum: Bing [Bot] and 13 guests
