Engine Management Light - Car wont start
Hi,
I own a 94 Calibra (C20XE). I'm experiencing intermittend problems where I would turn on the ignition, the engine management light would stay off and as a result the car wont start. I normally leave the ignition on for a while and the light would come on. I've tried restting the ECU without success. Anybodey experienced the same problem? Any help/suggestions would be appreciated.
edwin
Re: Engine Management Light - Car wont start
try changing the fuel pump relay mate
Its behind the drivers kick panel
Have you tried reading the fault codes?
Deffo tell tail of the fuel pump relay as above
