Idle Probems
Idle Probems
Car keeps idlin up n down and its not the idle control valve, wen the car is cold it idles perfect at 1100 rpm but as soon as it warms up it goes funny i think the electronic choke is at fault n tries to cut in wen the car gets warm
If it's not broke, fix it until it is...........
Re: Idle Probems
it dont have a choke of any sorts, could be the Water temp sensor
Re: Idle Probems
iv cleaned the valve twice, how cud it be the temp sensor
Re: Idle Probems
Because the ECU will fuel the engine differently when it's cold and hot.
Re: Idle Probems
where can i buy a temp sensor from?
Re: Idle Probems
James101 wrote:where can i buy a temp sensor from?
You can buy a CTS (coolant temp sensor) from your local Vaux dealer, they aint expensive.
Re: Idle Probems
how much u reckon m8, but i think it might be the wire that connects to the CTS as wen iv touched it the car revs like mad
Re: Idle Probems
CTS is about £8 from your local VX dealer
also if you read the fault codes one may be logged
Phantom
